Author Topic: STM32F103C8 diagnostic bootable binary freely available  (Read 14568 times)
Offline techman-001Topic starter
  • Electronics technician for the last 50 years
    • Mecrisp Stellaris Unofficial UserDoc
« on: December 15, 2019, 11:34:55 am »
Hi All,
Announcing a bootable 52.6kB diagnostic test kit binary for the STM32F103C8 such as used in the "Blue Pill Board". The size is under 64kB so that it can be flashed by OpenOCD to a MCU claiming only 64kB of Flash in the "Flash size register".
The purpose of this kit is to physically test the "hidden" 64kB second Flash block present on many of these chips and determine if it exists and if it is reliable. It does this by flashing all the bits from one to zero and back again.
Download here: https://sourceforge.net/projects/mecrisp-stellaris-folkdoc/files/STM32F103C8-DIAGNOSTICS.bin/download
Usage
1.   Flash the STM32F103C8-DIAGNOSTICS.bin image to your board with OpenOCD or whatever you normally use.
2.   Plug in a USB cable to the “Blue Pill” board and run a serial terminal program on your PC. This will also power the board.
3.   Enter “?” at the prompt to obtain the menu.
Menu
Enter ? for the menu
m - Menu; STM32F103R8 Test Kit
i - Device ID
b - Device Reported Flash Size in Bytes
t - TEST second 64kB Flash Memory block: 0x10000 - 0x1FFFF
d - Dump second 64kB Flash Memory block: 0x10000 - 0x1FFFF
e - Dump first  64kB Flash Memory block: 0x00000 - 0x10000
a - Author
l - License
q - Quit
Developed on a STM32F103C8 board (with the "hidden" second 64kB Flash block present) which is identical to a "Blue Pill", so it should work on all such boards.
Note: there are only three Block erasures and two Block flashes when this test is run, so the Flash wear is negligible.
A successful test looks like this:
Testing 64kB Flash block: 0x10000 - 0x1FFFF
Erasing
Flash with 1010101010101010 (0xAA)
Testing for 0xAA - OK
Erasing
Flash with 0101010101010101 (0x55)
Testing for 0x55 - OK
Erasing
~~~~~ ALL TESTS PASSED ~~~~~
More information here: https://mecrisp-stellaris-folkdoc.sourceforge.io/stm32f103c8-diags.html#stm32f103c8-diagnostics
« Last Edit: December 15, 2019, 11:48:15 am by techman-001 »
The following users thanked this post: BravoV, bingo600, thm_w, ebclr, coromonadalix, knapik, I wanted a rude username
Offline fmkit
  • Country: il
Re: STM32F103C8 diagnostic bootable binary freely available
« Reply #1 on: December 15, 2019, 11:48:17 am »
 have you found a real 64kb C8 ?  out of 20 chips I tried all were 128kb
« Reply #2 on: December 15, 2019, 12:14:20 pm »
Not yet. I only have 10 boards all with 128kB and 20 new 64 pin flatpack chips but with no ZIFF socket I won't be trying them for a while.
The reason I made the test image is because no one is sure whether the extra 64kB is ok or not, i.e. whether there may be a bad bit in there or not.
This test will find a bad bit.
Offline ebclr
« Reply #3 on: December 15, 2019, 01:02:45 pm »
Did you make this bin in FORTH ?
Offline fmkit
  • Country: il
« Reply #4 on: December 15, 2019, 04:11:26 pm »
Flash size can be read at  0x1FFF F7E0
Online rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #5 on: December 15, 2019, 04:41:01 pm »
I am using minicom on a Raspberry PI. First thing is to change the serial port from /dev/ttyUSB0 to /dev/ttyACM0.
Testing a CPU marked STM32F103C8T6:
stm32id
Die xy coords: 107806545
Wafer Number: 73
Lot_num ascii encoded  [23:0]: 0x00485478  | H T x
Lot_num ascii encoded [55:24]: 0x67244344  | g $ C D
Flash Size Register = 65536 Bytes
Erasing
Erasing
Erasing
My first test, though was accidentally a CKS CS32F103C8T6 that an ebay seller sold as the ST part.
EDIT: The part number is actually CKS32F103C8T6.
stm32id
Die xy coords: 16917299
Wafer Number: 50
Lot_num ascii encoded  [23:0]: 0x004D3712  | M 7 .
Lot_num ascii encoded [55:24]: 0x004E4B43  | . N K C
Erasing
FAILTEST: $10000  Data = $8C
FAILTEST: $10001  Data = $03
... all the way to
FAILTEST: $1CDE5  Data = $BD
FAILTEST: $1CDE6  Data = $00
FAILTEST: $1CDE7  Data = $00
blank check FAILTEST
It looks like the binary I just flashed. Apparently this chip reads the second 64K from the first.
« Last Edit: December 15, 2019, 06:48:28 pm by rhodges »
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
« Reply #6 on: December 15, 2019, 05:41:04 pm »
Yes I did.The binary is a complete Mecrisp-Stellaris Cortex-M3 Forth.
The following users thanked this post: ebclr
« Reply #7 on: December 15, 2019, 06:07:12 pm »
stm32id
Wafer Number: 73
Erasing
Erasing
Erasing
stm32id
Wafer Number: 50
Erasing
... all the way to
Thanks for the feedback, I wasn't able to verify proper bad chip detection with a bad chip because 'unfortunately' mine are all good ;-)
You're right, the bootable binary finishes at 0xCDE7 and is the same data as you have listed above.
Did you enable the Minicom log then press "d" to generate a dump of the binary data at 0x10000 - 0x1FFFF ?
Online rhodges
« Reply #8 on: December 15, 2019, 06:53:46 pm »
Yes. At the end, I saw the GPL text and some strings from your test code.
Offline bingo600
« Reply #9 on: December 15, 2019, 09:12:48 pm »
@techman-001
Nice test  :-+
And apparently "One bites the dust".
I was under the impression, that even those CKS had 2 x 64K.
Now to avoid those bluepill's on Ali/*bay
Thnx
/Bingo
« Reply #10 on: December 15, 2019, 10:36:50 pm »
Detective RHodges is on the job!
« Reply #11 on: December 15, 2019, 10:42:25 pm »
@techman-001
Nice test  :-+
Thnx
/Bingo
You're responsible anyway, for giving me the nudge to look into this.
Bluepills are like a box of chocolates .... but then one doesn't get many chocolates for under $2 these days.
« Reply #12 on: December 25, 2019, 10:00:25 am »
Now with a Xmas Day video  :popcorn:
"Did Santa bring your Blue Pill Board a free 64kB for Xmas ?"
https://youtu.be/xpTvd1Zhe0U
Offline Doctorandus_P
« Reply #13 on: January 08, 2020, 12:13:02 am »
I did not spend much time on this, as I'm not interested in binary blobs, but still had a look...
Then I saw it was soe FORTH thing, and that done it, closed the website.
I don't have anything against FORTH, but I am simply not interested in learning yet another language.
Offline BravoV
  • +++ ATH1
« Reply #14 on: January 14, 2020, 11:59:31 am »
Mr.Porter,
Reporting my BluePill, the one with the printed "RESRT" label for the RESET button.  :palm:
From this thread -> Cheap Bluepill, very likely it has fake STM32 right ?
Using your latest STM32F103R8 Test Kit v1.2 24Dec2019 version.
Result from "i" command :
stm32id
Die xy coords: 16985357
Wafer Number: 45
Lot_num ascii encoded  [23:0]: 0x004D3812  | M 8 .
Result from "b" command :
Flash Size Register = 131072 Bytes
Result from "t" command :
Erasing
Erasing
Erasing
« Last Edit: January 14, 2020, 12:16:18 pm by BravoV »
« Reply #15 on: January 14, 2020, 01:17:13 pm »
Mr.Porter,
stm32id
Wafer Number: 45
Erasing
Erasing
Erasing
G'day BravoV,
Thanks for the feedback.
I suspect that your chip may be a Chinese clone, the  "CKS32F103C8T6" because it uses hexadecimal for the LOT numbers, the same as yours and has 131072 bytes of ram. Finally your chip "Die xy coords" are very similar to Chinese clone #1 below.
STM32F103CX don't use hexadecimal for the LOT numbers.
Can you see any part numbers on your chips ? Either way they report 131072 bytes of flash and also test ok, that means they do have 131072 bytes of working flash as reported.
Here are two user submissions for CKS32F103C8T6's
Chinese clone #1
CKS32F103C8T6
Die xy coords: 16985099
Wafer Number: 42
Lot_num ascii encoded  [23:0]: 0x004D3512  | M 5 .
Lot_num ascii encoded [55:24]: 0x004E4B31  | . N K 1
Free
FLASH.. TOTAL REPORTED: 131072 USED: 51200 FREE: 79872
Chinese clone #2
CKS32F103C8T6
Die xy coords: 276745
Wafer Number: 42
Cheers,
Terry
Offline BravoV
  • +++ ATH1
« Reply #16 on: January 15, 2020, 02:59:14 am »
The interesting comparison when reading the "Lot" number in ASCII form :
Your others CKS string
M5.
.NK1
While mine has
M8.
.NKC
Newer CKS revision maybe ?  :-//
Also remember "F" character at the label position, as its printed at the 1st line, instead of 2nd line.
PS : Btw, regarding my report & photos, feel free to use it as you want, like for your blog.  :-+
« Last Edit: January 15, 2020, 03:01:51 am by BravoV »
« Reply #17 on: January 15, 2020, 04:34:10 am »
M5.
.NK1
While mine has
M8.
.NKC
You can disregard the ASCII output because those dots are HEX numbers and discarded by my program. As they're just lot numbers there is no version information.
Ah yes, the position of the F could well be a clue the chip is fake.
Thanks, I will definitely use your data in my blog as it may help others with Blue Pills.
Offline BravoV
  • +++ ATH1
« Reply #18 on: January 15, 2020, 08:35:20 am »
And coincidentally  ::) ... on CKS, they have the same style too which put the "F" at the 1st line.
I've read somewhere, that counterfeiters nowadays also want their product can be identified, as they need it for traceabilities in the supply chain and distribution, as cosmetic/appearance can be made almost perfect now.
I guess the reset button label (RESRT) is also deliberately misspelled.  :-//
« Reply #19 on: January 29, 2020, 01:18:25 pm »
Hi All,
Usage
Menu
i - Device ID
a - Author
l - License
q - Quit
G'day,
So far there have been 78 downloads of this diagnostics program. My thanks to those who provided feedback and data  :-+
I'm about to release V2 which incorporates improvements and bug fixes.
Before I finish this release are there any changes or additions you would like to see to the menu to improve this free diagnostic program ?
Cheers ...
Offline Mecanix
  • Country: cc
« Reply #20 on: February 04, 2020, 10:01:36 pm »
Great script, looking forward V2.0
Offline eliocor
    • rhodiatoce
« Reply #21 on: February 05, 2020, 12:05:10 am »
will it be possible to compile a version with PB9 active?
It is needed to enable the USB port on Maple Mini clones: https://stm32-base.org/boards/STM32F103C8T6-Maple-Mini-Clone.html
« Reply #22 on: February 05, 2020, 01:57:33 am »
Absolutely, great idea!
I'll enable USB for the Blue Pill, Olimex-P103 and the Maple-Mini, all at the same time on the new STM32F103C8 Diagnostic V2.
Different Firmware won't be needed.
Offline GromBeestje
« Reply #23 on: February 05, 2020, 08:11:39 am »
Could you also include PC13, as you did on my custom build?
« Reply #24 on: February 05, 2020, 08:56:39 am »
It *would* be my pleasure but ...
Blue pills have their user LED at PC13, any suggestions how we might accommodate this in the one build ?
An option jumper  perhaps ?
« Last Edit: February 05, 2020, 08:59:08 am by techman-001 »
