Author Topic: How to change Chineess front in STM32F103  (Read 1581 times)
Offline Md Mubdiul HasanTopic starter
  • Country: kr
  • Lets learn more to be more inspired in Electronics
« on: January 17, 2022, 08:01:24 am »
Hi there,
I am handling a project which has display application both for English and Korean front but I would like to add Chiness front in it.
For that reason, I have to add more thing in front.c and front.h etc.
I can made some Chineess front/ charecter using Note pad pixel and a software named KSX1001 frontedit
BMP to front can be made. i.e IMAGE SIZE-16*16, front size-32. Software output gives .c file when input is a .bmp file.
Take a look output c file for a given .bmp,
#define byte unsigned char
#define word unsigned int
extern code byte ImageFontTbl[];
code byte ImageFontTbl[]={ // ImageSize: 16 X 16
0xff,0x7f, // QQQQQQQQ.QQQQQQQ
0xc0,0x01, // QQ.............Q
0xdf,0x7d, // QQ.QQQQQ.QQQQQ.Q
}; // FontSize= 32
Now my original front.c file called image registor in  following way
const unsigned char IMAGE_16_16[COUNT_OF_16_IMAGE][32] = {
{0x11,0xaa,0x44,0x00,0xff,0x00,0xff,0x00,0x44,0xaa,0x11,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00}, // trace
{0x00,0xfe,0x02,0x12,0x12,0x12,0x12,0x82,0x42,0x22,0x12,0x0a,0x06,0xfe,0x00,0x00,0x00,0x3f,0x30,0x28,0x24,0x22,0x21,0x24,0x22,0x24,0x28,0x24,0x20,0x3f,0x00,0x00}, // Inverter
{0xff,0x01,0xfd,0xed,0xed,0xed,0xed,0x7d,0xbd,0xdd,0xed,0xf5,0xf9,0x01,0xff,0x00,0x7f,0x40,0x4f,0x57,0x5b,0x5d,0x5e,0x5b,0x5d,0x5b,0x57,0x5b,0x5f,0x40,0x7f,0x00}, // Reverse invertion
Another place they have represent korean front as follows,
const unsigned char FONT_HAN[0x168][32] = {
  {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
  {0x00, 0x04, 0x04, 0x04, 0xc4, 0xfc, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x18, 0x0e, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
  {0x00, 0x04, 0x04, 0xfc, 0xfc, 0x04, 0xfc, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x1f, 0x07, 0x18, 0x1f, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
 Even they have also present each letter
const unsigned char WAN_TO_JO[0x92E][2] = {
{0x88, 0x61},// 가
{0x88, 0x62},// 각
{0x88, 0x65},// 간
{0x88, 0x68},// 갇
{0x88, 0x69},// 갈
{0x88, 0x6a},// 갉
{0x88, 0x6b},// 갊
{0x88, 0x71},// 감
{0x88, 0x73},// 갑
{0x88, 0x74},// 값
{0x88, 0x75},// 갓
{0x88, 0x76},// 갔
Kindly suggest me what to do things for chiness. Does Image count has particular meaning to display it?
Does chiness front also need ASCI II charecter ? My front C also includes ASCI II.
Figure out the difference between IMAGE and FRONT of constant unsigned charecter.
« Last Edit: January 17, 2022, 08:11:53 am by Md Mubdiul Hasan »
Hasan
Offline thm_w
  • Non-expert
Re: How to change Chineess front in STM32F103
« Reply #1 on: January 17, 2022, 10:22:50 pm »
You mean "font" not "front" right.
As mentioned on the crosspost here: https://www.electro-tech-online.com/threads/how-to-change-chinese-front-in-stm32f103-c-programming.162865/
Look into GB2312 encoding.
You'll have to figure out how your specific application is displaying each font and convert your drawing to that type.
some examples here: https://learn.adafruit.com/adafruit-gfx-graphics-library/using-fonts
  • Country: kr
« Reply #2 on: January 18, 2022, 12:37:52 am »
Do you want me to use similar one?, https://string-functions.com/encodedecode.aspx
As I mentioned earlier, I can generate directly front from image file. Lets say image file is given.
STM32 firmware can do this job nicely. In my case code need modify. Take a look
void TextOut_5_4(int x, int y, char ch)
UINT i, yIndex;
UINT ArryIndex;
BYTE FontData;
yIndex = y % 8;
y /= 8;
for(i = 0; i < 4; i++)
ArryIndex = y * SCREEN_WITH + x + i;
FontData = FONT_5_4[(BYTE)ch][i] << yIndex;
pLCD_Screen[ArryIndex] |= FontData;
FontData = FONT_5_4[(BYTE)ch][i] >> (8 - yIndex);
pLCD_Screen[ArryIndex + SCREEN_WITH] |= FontData;
int TextOut(int x, int y, char *pString, BOOL bInvert)
int Size = 0;
while(*pString)
if(*pString & 0x80)
TextOut_Han(x, y, pString, bInvert);
pString += 2;
x += 16;
Size += 16;
else
TextOut_ASC_II_16(x, y, *pString, bInvert);
pString++;
x += 8;
Size += 8;
return Size;
Hasan
Online AndyC_772
« Reply #3 on: January 18, 2022, 08:32:24 am »
You might find this software helpful:
https://github.com/pavius/the-dot-factory
It converts bitmaps into C code in a variety of formats - you might find there's one that's similar to the way your existing software encodes other fonts.
  • Country: kr
« Reply #4 on: January 24, 2022, 05:02:54 am »
Your suggestion has already implemented. That was not main issue.
Hasan
