Hi!
Im reworking some code for a PCI18. For whatever reason the ADC "conversion complete" ISR is being executed even though the
ADC Interrupt Enable (ADIE) bit is not set in the PIE1 register.
ADIF is set in PIR1 when the ISR is called but why is it called?
Im using MPLAB X version 6.2.
Appreciate any input, i'm not to familiar with with PICs
Interrupt registers when ISR is calledISRADC config
