Author Topic: Speaker protect circuits.  (Read 1402 times)
Offline nigelwright7557Topic starter
    • Electronic controls
« on: July 26, 2019, 01:14:29 am »
As  I build a few amplifiers after nearly blowing up a speaker after one had a fault I came up with speaker protect circuit.
It just drops out a relay if it detects dc in the signal to the speaker.
I used a PIC12F509. I used 2 pins to detect the phase of the audio signal.
I also added a power up delay for the relay.
I then progressed the design to a solid state relay with dc detect, over current detect and power up/down detect.
I designed the pcb myself using PCBCAD360.
Offline Rick Law
Re: Speaker protect circuits.
« Reply #1 on: July 26, 2019, 02:45:10 am »
I am not as experienced as most here, but I have seen a number of PCB in photo attachments here - tens of dozens probably.
I must congratulate you.  I found your board very aesthetically pleasing.  It is very nice to look at.
« Reply #2 on: July 28, 2019, 09:27:37 pm »
My only criticism of the pcb is the size.
It really needs to be smaller to fit in the enclosure with the amplifer.
My latest revision is a bit smaller.
PCB was done with PCBCAD360.
Offline bob91343
« Reply #3 on: July 28, 2019, 10:14:07 pm »
Is relay dropout fast enough?  I would add a closure to short the speaker as well.  One major spike could still get through.
But yes, a nice job.  I have never been able to get myself into fabricating PC boards but would like to.  The software always seems awkward and often the libraries lack some devices I need.  Do you use ferric chloride?  Or do you just buy the boards?
« Reply #4 on: July 28, 2019, 10:27:02 pm »
Its a solid state relay, the mosfet's  drop out in micro seconds.
I only buy in pcb's from China. I can get 10 pcb's 10cm by 10cm for $5 plus p+p.
I often buy in a few different pcb's so the cost of p+p is shared out among them.
p+p is only expensive if you get 3 day delivery.
I use PCBWAY and JLCPCB.
