The approach that probably hasn't been discussed much is to ditch the dac, and use a PWM using Don Lancaster's Magic Sinewaves. This is a PWM stream that has harmonic cancellation - so for example with 6 PWM pulses per quadrant, you can have no harmonics below the 25th harmonic.
http://www.tinaja.com/msquant/retry_m/xxxx.shtml![](https://www.eevblog.com/forum/microcontrollers/sine-wave-lookup-table/?action=dlattach;attach=311353)
With a 16MHz clock, if you can get the cpu's PWM to output the right pulses, you can achieve 1Khz with 0.108% distortion - as long as you have a filter to cut out 25Khz and above. All without a DAC.
A little bit of work to turn one quadrant into 4 quadrants, but it all can be done. Not as easy or as versatile as a DAC, but for some applications, it can be perfect.
Don's calculator is written in Javascript, so you can capture the page and run it offline. The more pulses per quadrant (for a fixed clock), the higher you can push the first harmonic at the cost of distortion. With 2 pulses per quadrant, you can reduce the distortion to 0.04%, but the first harmonic is the 9th. If you have a fixed frequency, the ideal filter will have a notch (zero) at the frequency of the first harmonic - something like an elliptical filter. The first uncancelled harmonic is always really big.
