Looking at their circuit, it wants a 0-2R ESR capacitor on the output. I'm not sure how to qualify a capacitor against that requirement...
- ESR varies by frequency (though data sheets usually quote it at 120Hz AFAICT).
- It's not clear what frequency is relevant for the output of the LDO - in fact I can't find much about frequency in the LDO data sheet at all, what I can find is mainly frequency-dependent parameters...
- Looking at Murata's capacitor tool to see their ESR values, they vary from ~10R at 100Hz to a low of 6 milli-ohms at 1MHz
So if I were to choose to do it this way, how do I go about checking that the capacitors I choose will be suitable in terms of ESR (ok, I get X7R or X5R, the LDO datasheet says 1uF but they've used 4.7uF here, no problems there) ? Any clues ?
Clearly if the frequency to care about is > 1kHz, there's no problem, but how do I tell what the requirement needs ?
I guess it could be the clock frequency of the part (12MHz) or the internal frequency of the part (whatever it's overclocked to, like anyone's running this thing at 150MHz...) Or is it more to do with the LDO and I'm just missing it...
