Author Topic: Did cli() just destroyed everything?  (Read 1115 times)
Offline ppTRNTopic starter
« on: May 21, 2023, 07:06:25 pm »
Hi, I uploaded a very stupid program into my arduino yun (Atmega16U4)
void loop(){
   cli();
As soon as i uploaded it windows notified me that "usb device not responding" and told me that it might not be funcional. Tried to upload blink(), reset and immediatly try to upload, tried to reupload bootloader, nothing. Did I screw up?
Offline Ian.M
Re: Did cli() just destroyed everything?
« Reply #1 on: May 21, 2023, 08:41:53 pm »
cli() disables interrupts. Disabling interrupts crashes the USB link to the host after approximately 1ms when the Arduino fails to respond to USB link activity, resulting in a 'dirty' disconnect.
Try pressing the Arduino reset button twice in quick succession.  It should then enter USB bootloader mode, and you then have about eight seconds to select the correct COM port and upload a good sketch (e.g. 'Blink') before it drops out of bootloader mode and starts your FUBARed code.
The following users thanked this post: SiliconWizard, ppTRN
Offline barshatriplee
  • Country: bd
« Reply #2 on: May 22, 2023, 01:35:27 am »
Uploading a program that disables interrupts (cli()) in the loop() function of your Arduino Yun sketch can indeed cause issues with the board's functionality. Disabling interrupts can lead to a situation where the board becomes unresponsive or behaves unexpectedly.
Online brucehoult
« Reply #3 on: May 22, 2023, 04:24:51 am »
It's not even that it's in the loop() function. Even if it was in setup(), disabling interrupts and not re-enabling them will prevent responding to external interrupt-driven communication -- or even timers.
You should always endeavour to put as few instructions as possible between cli() and sei().
« Reply #4 on: May 22, 2023, 11:15:26 am »
Thanks, I did not know this boot mode. I will try it as soon as possible.
« Reply #5 on: May 22, 2023, 01:55:18 pm »
It worked! Thank you very much
