Author Topic: STM32F103 ports going bad?  (Read 1236 times)
Offline strawberryTopic starter
  • Country: lv
« on: January 08, 2023, 03:12:16 am »
B3,B4,C13,.. and some other are permanently high or low
first board couple years ago worked fine but this one didn't last one week
highly doubt about ESD
Offline Psi
Re: STM32F103 ports going bad?
« Reply #1 on: January 08, 2023, 03:34:37 am »
I would suspect latchup damaging the pins.
Does your circuit receive any voltages from external sources on I/O pins and are those protected so they cant exceed the MCU vcc rail?
Offline PCB.Wiz
« Reply #2 on: January 08, 2023, 04:44:21 am »
What connects to those pins ?
If you check the strength of high or low, what drive resistance do you get ?
Offline ozcar
« Reply #3 on: January 08, 2023, 05:10:55 am »
PB3 and PB4 are 5V tolerant, PC13 is not, and PC13 also has lower drive strength.
  • Country: lv
« Reply #4 on: January 08, 2023, 11:21:35 am »
3.3V
LCD connected to B3,B4
default button to C13 (100n + pullup 4.7k)
MODE=0 CNF=1 ODR=0 IDR=0 (can pulll up with 47R IDR = 1)
Offline Psi
« Reply #5 on: January 08, 2023, 11:45:32 am »
Does the LCD have its own boost circuit that produces a higher voltage to run a backlight or led array?
Offline wek
  • Country: sk
« Reply #6 on: January 08, 2023, 12:14:28 pm »
C13 means PC13? It's always better to use the same terminology as the manufacturer so that we don't need to guess.
Then it's most likely damaged input.
Is this a genuine STM32F103 bought from a reputable source?
JW
  • Country: lv
« Reply #7 on: January 08, 2023, 12:49:18 pm »
5V to 3.3V LDO, no switching PSU, both LCD and MCU on 3.3V
if LCD caused damage to stm32, but LCD works as I can tell
PB3 ,PB4 could be damaged during shipping??
another weird bug is when clearing display but instead it do LCD software reset( but can draw black pixels without any problem??)
Maybe CubeIDE is optimizing/generating wrong code
PC13 is reading input state correctly
from Mouser from eu stock
Offline wek
  • Country: sk
« Reply #8 on: January 08, 2023, 03:40:03 pm »
OK so the problem is only with PB3 and PB4?
If you disconnect then from the LCD, still problem?
How are the GPIOB registers set?
JW
Offline DavidAlfa
« Reply #9 on: January 08, 2023, 05:56:24 pm »
Unlikely, better show your code.
  • Country: lv
« Reply #10 on: January 08, 2023, 07:28:09 pm »
47R can pull PC13 high to trigger interrupt. too low impedance for input port
static void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOC, RST_Pin|CS_Pin|GPIO_PIN_11|GPIO_PIN_12, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, RD_Pin|WR_Pin|DC_Pin|LD2_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOB, D0_Pin|D1_Pin|D2_Pin|D10_Pin
                          |D11_Pin|D12_Pin|D13_Pin|D14_Pin
                          |D15_Pin|D5_Pin|D6_Pin|D7_Pin
                          |D8_Pin|D9_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : BTN_Pin */
  GPIO_InitStruct.Pin = BTN_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING_FALLING;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(BTN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : RST_Pin CS_Pin PC11 PC12 */
  GPIO_InitStruct.Pin = RST_Pin|CS_Pin|GPIO_PIN_11|GPIO_PIN_12;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pins : RD_Pin WR_Pin DC_Pin LD2_Pin */
  GPIO_InitStruct.Pin = RD_Pin|WR_Pin|DC_Pin|LD2_Pin;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pins : D0_Pin D1_Pin D2_Pin D10_Pin
                           D11_Pin D12_Pin D13_Pin D14_Pin
                           D15_Pin D5_Pin D6_Pin D7_Pin
                           D8_Pin D9_Pin */
  GPIO_InitStruct.Pin = D0_Pin|D1_Pin|D2_Pin|D10_Pin
                          |D8_Pin|D9_Pin;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
 /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI15_10_IRQn, 5, 0);
  HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
/* USER CODE BEGIN 4 */
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) {
if (GPIO_Pin == GPIO_PIN_13) {
menu++;
if (menu == 12) {
menu = 0;
} else {
__NOP();
Offline DavidAlfa
« Reply #11 on: January 08, 2023, 07:52:58 pm »
Is it a blue pill? If so, board button is PA1, PC13 is the led.
If it's working with other boards, try resoldering the stm32 (Maybe there's some junk between the pins?), but seems like the STM32 is bad.
« Last Edit: January 08, 2023, 08:16:24 pm by DavidAlfa »
