Well you are making a lot of assumptions.
Who told me that it needed an S2, one of the latter authors who confirmed that the original project with an ESP32, ran out of memory.
The code still doesn't compile for a non S2 for all the versions of the original code.
I don't care if the code fits or not, it doesn't compile. Iv'e still yet to program anything because I do not have an S2.
Of course the json file was installed long ago.
The compiler warnings had never been turned off until I kept getting errors weeks ago.
Why would any good programmer ever turn off errors anyway it is counter intuitive to doing the job right.
Yes, the settings are exactly the same as yours which are still the same as when I started.
Any way I want more memory and PSRAM just because, not because it will fix this. I want the max because I don't like to buy things twice. More PSRAM equates to spiffs not running short of space.
Expressif's site is all over the map and still doesn't give a correct part number for 2M or 4M (if available) to order from a vendor-distributor.
Quote from: tooki on Yesterday at 08:10:44
