Author Topic: Arm China STAR-MC1 processor  (Read 5857 times)
Offline ataradov
    • Personal site
Re: Arm China STAR-MC1 processor
« Reply #25 on: January 18, 2023, 10:07:25 pm »
A bit confusing, and quite a jump.
Sometimes vendors have higher CLKs for PWM blocks, for finer PWM steps, maybe it's related to that ?
No, they specifically mention "The maximum frequency of the AHB and the APB domains is 168MHZz." ("MHZz" is in the datasheet :) ). The core is in the AHB domain, so presumably can run at this clock.
This looks like some extreme overclocking, most likely at the expense of reliability.
Alex
Offline koendv
« Reply #26 on: January 21, 2023, 09:55:13 am »
It looks like a generic STM32, until you look closer.
- Clock generation is completely different, allowing for higher speeds.
- STM32 spi can do spi frames from 4 to 16 bits. The MM32 SPI has an extra register, where you can set frame sizes from 1 to 32 bit
If I compare the Star-MC1 MM32F5270 with the Cortex-M3 MM32F3270, I get the following impression.
- the F3270 has 128 kbyte ram at 0x20000000, and 512 kbyte flash.
- they ripped out the Cortex-M3 core and replaced it with the Star-MC1
- but the Star-MC1 has 32kbyte tightly coupled ram at 0x2000000 e.g. for stack
- so they moved the 128 kbyte ram to 0x3000000
- space got a bit tight, so they lowered the amount of flash from 512kbyte to 256kbyte.
But this is just the impression I get.
« Last Edit: January 21, 2023, 10:26:18 am by koendv »
