Hello,
I'm trying to get a bit more experience with reverse engineering and I've picked a little embedded board that does audio processing as my first victim.
Few info about the board:- main uC is
i.MX RT1170 which has 1GHz Cortex M7 + 400MHz Cortex M4 and 2Mb of ram
- flash is
IS25WP032 in an easy to access 8 pin SOIC package
What I've got so far:- I've located a 20 pin debug connector and found UART, only one pin (TX) is pulled up so I think RX pin resistor is not populated for release boards.
- I have a log of the device booting up, it appears to have a custom second stage bootloader (log attached to the bottom of the post) rather than using uBoot which is what I've seen from this manufacturer previously (bummer as I was hoping to get uboot prompt)
- I've dumped the firmware of the device. It's encrypted and is a bit over 1Mb in size. Size of the firmware + the bootloader situation makes me think this device is not running Linux like other devices from the same manufacturer I've previously inspected
- The device is fused (so JTAG should be disabled)
- I've figured out a way to put the device in SDP boot mode
- I've got NXP's
SPSDK python tooling suite running and I've managed to read a few flags (blhost get-property) with it. However when trying to read memory with spsdk blhost -u -- read-memory the device responds with "command not supported" error. The SDP boot mode times out after 10 seconds or so so it's a bit painful to explore blhost commands it supports.
So here I am at this point and I'm looking for ideas on how to progress. Having read some of NXP datasheets and application notes my understanding is that the aes key used to decrypt the firmware is stored on device and will be hard or impossible to extract. The firmware is also decrypted by the device "on the fly" (and then put in RAM?) so it's most likely never in the flash memory in decrypted form.
Ideally my end goal would be to have the firmware decoded so that I can put it into ghidra and explore it more.
What are my options? Looking for even the craziest ideas. I don't care if I break the device in the process and I am willing to spend unreasonable amount of time on this as I'm not in rush, not doing this for money and the journey is the goal
I was most impressed with this forum's efforts to hack scopes so I hope some experienced hackers chime in.
Thanks!
Bootloader log
Bootloader Version 1.2.0
flash_area_open rc = 0
Bootloader chainload address offset: 0x100000
Reset_Handler address offset: 0x100400
Jumping to the image...
calculated msp 0x0x30100400 reset 0x0x30100404
