All,
I have been reviewing the following code from gman4925. I would like to see if this could be modified to include a button that would break out of the interactive mode using the encoder for rotation to turning the stepper clockwise until another button is pushed using a potentiometer for speed control.
Has anyone done this that could help me.
thanks,
-Bkukuk62
//Arduino code for controlling stepper motor from encoder
//video at
//reconstructed code from 5+ years ago
//untested in current form
#define encoder_a 2 //encoder a = arduino pin 2
#define encoder_b 3 //encoder b = arduino pin 3
#define motor_step 4 //motor step = arduino pin 4
#define motor_direction 5 //motor direction = arduino pin 5
volatile long motor_position, encoder;
void setup ()
//set up the various outputs
pinMode(motor_step, OUTPUT);
pinMode(motor_direction, OUTPUT);
// then the encoder inputs
pinMode(encoder_a, INPUT);
pinMode(encoder_b, INPUT);
digitalWrite(encoder_a, HIGH);
digitalWrite(encoder_b, HIGH);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, encoderPinChangeA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, encoderPinChangeB, CHANGE);
encoder = 0;
void encoderPinChangeA()
if (digitalRead(encoder_a) == digitalRead(encoder_b))
encoder--;
else
encoder++;
void encoderPinChangeB()
if (digitalRead(encoder_a) != digitalRead(encoder_b))
encoder--;
else
encoder++;
void loop()
//do stuff dependent on encoder position here
//such as move a stepper motor to match encoder position
//if you want to make it 1:1 ensure the encoder res matches the motor res by dividing/multiplying
if (encoder > 0)
digitalWrite(motor_direction, HIGH);
digitalWrite(motor_step, HIGH);
digitalWrite(motor_step, LOW);
_delay_us(200);
motor_position++;
encoder = 0;
else if (encoder < 0)
digitalWrite(motor_direction, LOW);
_delay_us(200);
motor_position--;
encoder = 0;
