Author Topic: Sparkfun BlueSMiRF - Arduino Communication  (Read 422 times)
Offline simba15Topic starter
« on: November 21, 2022, 07:51:04 pm »
Hi there EEVblog,
I have purchased a couple of sparkfun BlueSMiRF Bluetooth modules and intend to use them with Arduino.
I have followed the instructions at
https://learn.sparkfun.com/tutorials/using-the-bluesmirf/introduction?_ga=2.130510221.300646374.1669038264-572122409.1669038264
When I get to the page where I should receive data from the device but I get nothing.
https://learn.sparkfun.com/tutorials/using-the-bluesmirf/example-code-using-command-mo
I send $$$ and the device changes into "Configuration Mode" but there is no data from the device. ( I have tried another cable and other pins ( 4/5) but no change).
I have tried a few alternatives and other version of the code but all seem to have no ability to return any data from the device.
I also tried the steps to connect to a PC and the Pc always responds with  error 1186 when trying to open the com port. ( I was able to get 1 connection, but the pc was in raw not line mode)
Any suggestions or solutions would be greatly appreciated ( or alternatives that have better results)
Thanks,
Re: Sparkfun BlueSMiRF - Arduino Communication
« Reply #1 on: November 22, 2022, 04:27:06 pm »
So turns out the issue is the Arduino Mega that was used.
It is an official Arduino Mega ( I have about 20, all work the same) but when I tested this setup with an Arduino UNO (official also) It works perfect.
I have seen other issues with the Arduino Mega ( Clone but it would lockup when enabling the watchdog timer).
Or just RTFM, Arduino mega has specific pins for SoftwareSerial library.
« Last Edit: November 22, 2022, 08:32:32 pm by simba15 »
