Author Topic: PSoC examples  (Read 51423 times)
Offline mrflibble
Re: PSoC examples
« Reply #75 on: October 15, 2014, 03:58:02 pm »
Thanks. Noticed this one as well: http://www.cypress.com/?docID=42670
It seems a bit like the UDB's are primitives which you can then instantiate in your verilog.
Anyways, watching this one to get an impression:
Offline miguelvp
Re: PSoC examples
« Reply #76 on: October 15, 2014, 04:53:09 pm »
They have multiple ways to access the datapaths and using verilog and udb components or actually use their stand alone datapath configuration tool.
More information here:
http://www.cypress.com/?docID=49891
Link came from the first link in here:
http://www.cypress.com/?rID=69959
Offline jmole
    • My Portfolio
Re: PSoC examples
« Reply #77 on: October 22, 2014, 03:03:10 am »
The new "simple" UDB editor is a great place to start creating your first UDB components. I was pretty overwhelmed at first, but eventually got the hang of it, and managed to configure a hybrid UDB/verilog component that drives TLC5940 LED Drivers. It's nice, because you can use the simplified UDB editor to get a feel for what the UDB does, then take the verilog code it generates and incorporate it into a larger component.
Preliminary code/project file is up on github, but still needs quite a bit of work before it's ready for public use. I need to generalize it further to enable daisy-chained units, and add a Customizer GUI (perhaps the most difficult part of the PSoC Component workflow) to make it really usable.
Preliminary code is here: https://github.com/jmole/PSoC_TLC5940
Offline miguelvp
Re: PSoC examples
« Reply #78 on: October 22, 2014, 03:13:37 am »
You should check Kees_library has a lot of goodies:
https://github.com/EngineerBro/GlowTime
I'm trying this GlowTime project to drive a 32x32 panel but I I noticed his library and it's quite cool, so far I've used the KEES_PinHelper that if you name the pins certain way it assigns them directly, case insensitive too.
So p0_0_blah will be assigned to P0[0] you can use P0_0_blah as well for the same result. Or you can do thispin_P0_0 for the same pin definition. Pretty handy.
Also he has a lot of blocks on that community library and some PSoC Sensei blocks as well are in there.
Edit: KEES stands for Chris Keeser (Cypress employee).
PSoC Sensei is Brad Budlong (Cypress employee as well) I believe:
http://www.cypress.com/?id=2401
Edit2: hmm seems he has an interesting project here as well:
https://github.com/EngineerBro/Carbon (quadcopter on PSoC 4????)
« Last Edit: October 22, 2014, 03:20:11 am by miguelvp »
