Author Topic: Programming CH32V003 - NO WCH LINKe  (Read 212 times)
Online ppTRNTopic starter
« on: October 03, 2024, 02:48:35 pm »
Hi everyone,
I recently bought a ch32v003 dev board, but I did not purchase a programmer (also by wch) because I thought it was just a usb to uart bridge.
Turned out it isn't. It uses a proprietary standard to program the device!
Do you guys know any easy way to program it in any other way or do you suggest to just buy a programmer?
Cheers!
Edit: typos
« Last Edit: October 03, 2024, 02:56:34 pm by ppTRN »
Offline Sacodepatatas
Re: Programming CH32V003 - NO WCH LINKe
« Reply #1 on: October 03, 2024, 05:31:33 pm »
The easiest way is to buy the programmer. It's about 5€ and comes cheaper if you buy the official set that included a proper dev board, 5 more ICs, and the programmer itself (be careful because you might be tempted to purchase the WCH-Link programmer. It isn't compatible, you need the WCH-LinkE version). But you have more alternatives. Although the SWIO interface is propietary, It is open so there are several implementations. Check out this link...
https://github.com/cnlohr/ch32v003fun
« Reply #2 on: October 03, 2024, 06:33:27 pm »
Thank you. I think I will eventually buy the programmer but I want to try use an arduino just for the sake of it.
The link you provided is very usefull.
