Hi all,
Anyone has a DSlogic able to advise? I just bought a DSlogic to test out. To test this newly bought LA and the DSview whether it work as expected, I used a serial terminal software in my setup to send a ascii text "testing" to USB-RS485 device, then to the LA probe, and LA capture and send the reading to the DSview. The DSview was able to display 7 characters captured but it showed all zero on the data. Is there anything I did wrong?
You may refer to attachment for my setup.
Your advise is greatly appreciated
