I mean, if you do embedded programming, you'd expect:
for (uint8_t count=1; count != 0; count++) {
// Stuff
to terminate after about 255 loops, right? Not be optimized into an infinite loop because "integer overflow behavior is undefined and the optimizer decided that you'll never hit zero by incrementing an unsigned variable" ? Ha hah! Surprise!
This is not accurate because
"A computation involving unsigned operands can never overflow,
because a result that cannot be represented by the resulting unsigned integer type is
reduced modulo the number that is one greater than the largest value that can be
represented by the resulting type". (C99 6.2.5.9)
To nitpick, this citation doesn't apply here because of the integer promotion. When "count++" is calculated, the value of "count" must be fetched, converted to "int" (this is called integer promotion), then 1 is added and the result is assigned back to "count". While assigning the value to "count", the result is converted to the type of "count" using this rule:
"if the new type is unsigned, the value is converted by repeatedly adding or
subtracting one more than the maximum value that can be represented in the new type
until the value is in the range of the new type".(C99 6.3.1.3.2)
Thus, 255+1=256 should be converted to 0 when assigned to "count" (which is uint8_t), producing the exact result you would expect.
Therefore, the code should work as expected. Optimizing it to infinite loop would be against C99.
The development of the C standard took a long time and a lot of thinking, so it is very good at producing the most reasonable behaviour for the vast majority of the situations.
