There's now an updated datasheet with the 'E9' erratum spelled out in detail. The TL;DR version is - treat GPIO inputs as if they're TTL and you'll be fine. In other words any pull-downs need to be strong ones (lower than 8k2 at current estimates). This rather rules out use of the internal pull-downs.
EDIT2:
On reflection, that errata, seems way, way too complicated, to expect, the wide range of differing skill levels, from beginner to expert, to be able to reliably use these RP2350's (Pico 2's etc). In my opinion. Since inputs, are such an important part of some embedded projects.
Thanks for that information!
I would like to add, to that.
First, one of the (apparently a) Raspberry Pi people/engineers/moderators, seems to have said, they are considering if they need to (as a result), release an updated version of the chip, on the official Raspberry Pi Forums. I'm not sure if that decision has been made yet, or not.
Second, (partly based on what other(s) on unofficial sources, have said), that may not really work out, in practice. Because if it is (or is also used as, sometimes, by the hardware), an analogue input, it may not have such strong pull-low drive characteristics, depending on the exact circuit configuration/design used.
E.g. An LDR (Light Dependent Resistor), whose resistance depends on the light level, and might be fed into an ADC pin, for reading the ambient light level, without an op-amp buffer. Could easily, sometimes be in the problematic (too high), resistance range, and then latch up the pin.
N.B. I'm NOT familiar enough with the exact details of it all, to be 100% certain, so maybe the exact scenario, has to be different.
EDIT:
Looking at the updated datasheet, version information follows:
build-date: 2024-09-06
build-version: 05c4754-clean
Source:
https://datasheets.raspberrypi.com/rp2350/rp2350-datasheet.pdfGPIO
RP2350-E9
Reference RP2350-E9
Summary Increased leakage current on Bank 0 GPIO when pad input is enabled
Affects RP2350 A2
Appendix H: Documentation Release
History
6 September 2024
• Enhanced E9 errata description with additional details.
N.B. More information in actual datasheet, I've not copied the multiple graphs, included in the datasheet, about this issue.
Description For GPIO pads 0 through 47:
Increased leakage current when Bank 0 GPIO pads are configured as inputs and the pad is somewhere
between VIL and VIH (the undefined logic region).
When the pad is set as an input (input enable is enabled and output enable is disabled) and the voltage
on the pad is within the undefined logic region, the leakage current exceeds the standard specified IIN
leakage level. During this condition the pad can source current (the exact amount is dependent on the
chip itself and the exact pad voltage, but typically around 120μA). This leakage will hold the pad at
around 2.2 V as that is the effective source voltage of the leakage, and can only be overcome with a
suitably low impedance driver / pull.
Note that the pad pull-down (if enabled) is significantly weaker than the leakage current in this state and
therefore is not strong enough to pull the pad voltage low.
Driving / pulling the pad input low with a low impedance source of 8.2 kΩ or less will overcome the
erroneous leakage and drive the voltage below the level where the leakage current occurrs, so in this case
if the pad is driven / pulled low it will stay low.
The erroneous leakage only occurs (and continues to occur) when the pad input enable is enabled;
disabling the input enable will reset (remove) the leakage.
The pad pull-up still works. If enabled it will pull the pad to IOVDD as it will pull the input voltage out of the
problematic range.
The voltages and currents above are based on IOVDD at 3.3 V. For IOVDD at 1.8 V the effective source
voltage of the leakage becomes 1.8 V and the peak current is around 30μA. This is effectively a pull-up
(separate to the standard pad pull-up) when the pad voltage is between 0.6 V and 1.8 V.
These graphs show the leakage current versus pad input voltage for a typical chip for IOVDD at 3.3 V
Figure 152 and 1.8 V Figure 153.
In detail, this issue presents under the following conditions, for any GPIO 0 through 47:
1. The voltage on the pad is in the undefined logic region.
2. Input buffer is enabled in GPIO0.IE
3. Output buffer is disabled (e.g. selecting the NULL GPIO function)
4. Isolation is clear in GPIO0.ISO, or the previous were true at the point isolation was set
When all of the above conditions are met, the input leakage of the pad may exceed the specification.
This issue may affect a number of common circuits:
• Relying on floating pins to have a low leakage current
• Relying on the internal pull-down resistor
If the internal pull-up is enabled then any floating signal will be pulled high thus removing increased
leakage condition as the excess leakage is only sourcing current. This of course can’t prevent the
increased leakage if the pad is fed via a strong source e.g. strong potential divider.
Note that this does not affect the pull-down behaviour of the pads immediately following a PoR or RUN
reset, because the input enable field is initially clear. The pull-down resistor functions normally in this
state.
This issue does not affect the QSPI pads, which use a different pad macro without the faulty circuitry.
The USB PHY’s pins are also unaffected.
This issue does also affect the SWD pads, which use the same fault-tolerant pad macro as the Bank 0
GPIOs. However, both SWD pads are pull-up by default, so there is no ill effect.
RP2350 Datasheet
GPIO 1342
Workaround If pad pull-down behaviour is required, clear the pad input enable in GPIO0.IE (for GPIOs 0 through 47) to
ensure that the pad pull-down resistor pulls the pad signal low. To read the state of a pad pulled-down
GPIO from software, enable the input buffer by setting GPIO0.IE immediately before reading, and then re-
disable immediately afterwards. Note that if the pad is already a logic-0, re-enabling the input does not
disturb the pull-down state.
Alternatively an external pull-down of 8.2 kΩ or less can be used.
Note that PIO programs can’t toggle pad controls and therefore external pulls may be required, depending
on your application.
As normal, if ADC channels are being used on a pin, clear the relevant GPIO input enable as stated in
Section 12.4.3.
Fixed by Documentation
