electric toothbrush don't needs so powerful MCU, it's obviously too expensive and too powerful for this task.
It uses, a very complicated, 4 phase, ultrasonic cleaning pattern, which gets around all pre-existing and currently active patents. Needing the full power of all 3 PIO units.
I'm planning to call it the Hyperphetical-SuperClean-2350, with
OTP unit for increased reliability and cleaning power.
Even with electric toothbrush example you might accidentally write something in OTP when you play with MCU during development and lose it... This is the main risk that I see for myself as for developer.
But I might also accidentally destroy the prototype, with static electricity, by accidentally setting the bench power supply to silly high voltages, or be so frustrated with someone on a forum, that I throw the only prototype, hard against a wall, smashing it to pieces.
Yes, the prototype electric toothbrush,
could be run over by a bus, with a big advert on the side of the bus that says "Vote NO to OTP".
But life is full of risks, without going wildly overboard, with worrying about things, which are extremely unlikely to happen.
