Author Topic: TI_ISR_TRAP MSP430FR6989  (Read 3153 times)
Offline MattjdTopic starter
« on: October 08, 2017, 05:14:34 pm »
Hello,
When I am executing my code, if I press down the button P1.1 during debugging mode, LED associated with P1.0 stops blinking. When I pause the debugging session, this file pops up
;* ISR_TRAP.ASM - v16.9.4                                                     *
;* Copyright (c) 2003-2017 Texas Instruments Incorporated                     *
;* http://www.ti.com/                                                         *
;*  Redistribution and  use in source  and binary forms, with  or without     *
;*  modification,  are permitted provided  that the  following conditions     *
;*  are met:        *
;*     Redistributions  of source  code must  retain the  above copyright     *
;*     notice, this list of conditions and the following disclaimer.          *
;*     Redistributions in binary form  must reproduce the above copyright     *
;*     notice, this  list of conditions  and the following  disclaimer in     *
;*     the  documentation  and/or   other  materials  provided  with  the     *
;*     distribution.                                                          *
;*     Neither the  name of Texas Instruments Incorporated  nor the names     *
;*     of its  contributors may  be used to  endorse or  promote products     *
;*     derived  from   this  software  without   specific  prior  written     *
;*     permission.                                                            *
;*  THIS SOFTWARE  IS PROVIDED BY THE COPYRIGHT  HOLDERS AND CONTRIBUTORS     *
;*  "AS IS"  AND ANY  EXPRESS OR IMPLIED  WARRANTIES, INCLUDING,  BUT NOT     *
;*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR     *
;*  A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT     *
;*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,     *
;*  SPECIAL,  EXEMPLARY,  OR CONSEQUENTIAL  DAMAGES  (INCLUDING, BUT  NOT     *
;*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,     *
;*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY     *
;*  THEORY OF  LIABILITY, WHETHER IN CONTRACT, STRICT  LIABILITY, OR TORT     *
;*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE     *
;*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.      *
;-- default ISR handler if user does not supply
;-- simply puts device into lpm0
    .sect ".text:_isr:__TI_ISR_TRAP"
.align 2
.global __TI_ISR_TRAP
__TI_ISR_TRAP:
        BIS.W     #(0x0010),SR
        JMP __TI_ISR_TRAP
        NOP                     ; CPU40 Compatibility NOP
;* BUILD ATTRIBUTES                                                           *
;*    HW_MPY_INLINE_INFO=1:  file does not have any inlined hw mpy            *
;*    HW_MPY_ISR_INFO   =1:  file does not have ISR's with mpy or func calls  *
        .battr "TI", Tag_File, 1, Tag_HW_MPY_INLINE_INFO(1)
        .battr "TI", Tag_File, 1, Tag_HW_MPY_ISR_INFO(1)
My code
// Author: Matt Dxxxxxxxx
// Lab: 3
// Section: Button Delay
// Device: FR6989
#include <msp430.h>
volatile unsigned int button_count;
int main(void)
    WDTCTL = WDTPW | WDTHOLD;               // stop watchdog timer
    PM5CTL0 &= ~LOCKLPM5;                   // Disable the GPIO power-on default high-impedance mode
                                            // to activate previously configured port settings
    P1DIR |= BIT0;                          // Set P1.0 to output direction -- LED
    P9DIR |= BIT7;                          // Set P9.7 to output direction --- LED
    P1DIR &= ~BIT1;                         // Set P1.1 to button input
    P1REN |= BIT1;                          // Enable Pull Up Resistor for pin1.1
    P1OUT |= BIT1;                          //SPECIFIED AS A PULLUP FOR P1.1
    P1IES &= ~BIT1;                          //Have flag set on Low to High
    P1IE |= BIT1;                           //enable interrupts for Pin 1.1
    P1IFG &= ~BIT1;                         //Clear Pin 1.1 flag so no immediate interrupt
    P1DIR &= ~BIT2;                         // Set P1.2 to button input
    P1REN |= BIT2;                          // Enable Pull Up Resistor for pin1.2
    P1OUT |= BIT2;                          //SPECIFIED AS A PULLUP FOR P1.2
    P1IES |= BIT2;                          //Have flag set on High to Low
    P1IE |= BIT2;                           //enable interrupts for Pin 1.1
    P1IFG &= ~BIT2;                         //Clear Pin 1.1 flag so no immediate interrupt
    TA0CCTL0 |= CCIE;                        // TA0CCR0 interrupt enabled
    TA0CCR0 = 3277;                          //Set value of TA0CCR0 for comparison
    TA0CTL |= TASSEL_1 + MC_1;              //Pick ACLK & Set Counter to Up Mode
    TA0CTL |= TACLR;                        //Clear Timer A0
    TA1CCTL0 |= CCIE;                      // TA1CCR0 interrupt enabled
    TA1CCR0 = 512;                         //Set value of TA1CCR0 for comparison
    TA1CTL |= ID_3;                        //Divide clock by 8, ACLK will be chosen, so 4096 hz
    TA1EX0 |= TAIDEX_7;                    //Divide ACLK further by 8 to 512 hz
    TA1CTL |= TACLR;                       //Clear Timer A1
    _enable_interrupt();
    for(;;)
        while(!(P1IN & BIT1))
            if(TA1R == 0)
                TA1CTL |= TASSEL_1 + MC_1;    //Pick ACLK & Set Counter to Up Mode
#pragma vector = TIMER0_A0_VECTOR
__interrupt void TimerA0_ISR (void)
    P1OUT ^= BIT0;
#pragma vector = TIMER1_A1_VECTOR
__interrupt void TimerA1_ISR (void)
    P9OUT ^= BIT7;
    button_count++;
#pragma vector = PORT1_VECTOR
__interrupt void P1_ISR(void)
    switch(P1IV)
    case P1IV_P1IFG1:
            TA0CCR0 = 3277*button_count;          //slow down blink speed
            break;
    case P1IV_P1IFG2:
            TA0CCR0 = 3277;                       //reset blink speed
            break;
What I am attempting to do is count the number of seconds that I have the button associated with P1.1 held down, so when I hold down the button, Timer A1 gets activated, every second it enters TimerA1_ISR, blinks LED P9.7 (to indicate a second has passed), and increments button_count. When I let go of button P1.1, I should enter P1_ISR and change the value TA0CCR0, which alters the led frequency (slowing it down) of P1.0
I think something is wrong with my TimerA1_ISR but Idk what. I set a break for it, but never enter it. When I hold down the button, the LED P1.0 stops blinking, I pause the debugger and the isr_trap comes up.
edit: when the LED stops blinking and I pause the debug, SR_CPUOFF = 1, indicating LPM0, which makes sense that the LED stops blinking.
« Last Edit: October 08, 2017, 05:21:42 pm by Mattjd »
Offline Cervisia
Re: TI_ISR_TRAP MSP430FR6989
« Reply #1 on: October 09, 2017, 10:57:26 am »
Those interrupt vector names can be confusing. From the gcc header file:
#define TIMER3_A1_VECTOR        (33)                     /* 0xFFD0 Timer3_A2 CC1, TA */
#define TIMER3_A0_VECTOR        (34)                     /* 0xFFD2 Timer3_A2 CC0 */
#define TIMER2_A1_VECTOR        (36)                     /* 0xFFD6 Timer2_A3 CC1, TA */
#define TIMER2_A0_VECTOR        (37)                     /* 0xFFD8 Timer2_A3 CC0 */
#define TIMER1_A1_VECTOR        (39)                     /* 0xFFDC Timer1_A3 CC1-2, TA1 */
#define TIMER1_A0_VECTOR        (40)                     /* 0xFFDE Timer1_A3 CC0 */
#define TIMER0_A1_VECTOR        (44)                     /* 0xFFE6 Timer0_A5 CC1-4, TA */
#define TIMER0_A0_VECTOR        (45)                     /* 0xFFE8 Timer0_A5 CC0 */
The following users thanked this post: Mattjd
« Reply #2 on: October 09, 2017, 05:18:19 pm »
How did you access that to find all of this?
Offline Cervisia
« Reply #3 on: October 09, 2017, 07:20:36 pm »
Er, I just opened the msp430fr6989.h file in an editor and searched for those symbols.
