Greetings,
i have noticed something odd with the output voltage on my PIC 12F683, the CCP1 module outputs around a signal that is around 0.9 Vpp, and this strikes me as odd, i have a scope on it, the duty cycle changes as i would expect. Maybe I'm naive, but i would have expected a 5Vpp signal coming from the 12f683.
The only thing i can think of that is that it has something to do with this maybe
110x = PWM mode active-high
111x = PWM mode active-low
But I'm not clear on what this mean, but i suspect that it has something to do with the duty cycle is counted on high or low, but I'm not sure.
So if anyone could enlighten me it would be great, I'm sure its something simple
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
