Author Topic: Orange Pi One Woes  (Read 19295 times)
Offline martinayotte
Re: Orange Pi One Woes
« Reply #50 on: January 05, 2017, 05:10:20 pm »
Instead of using crappy images, simply use the ones from Armbian : armbian.com
Offline lemi1
« Reply #51 on: January 05, 2017, 05:15:38 pm »
Now hawe instaled ubuntu 15,4 and run torrent client deluge.Try to instal print server cups and nothing hapening.I am lost
Poslano z mojega ONE A2003 z uporabo Tapatalk
« Reply #52 on: January 05, 2017, 05:20:20 pm »
Offline lemi1
« Reply #53 on: January 05, 2017, 05:21:06 pm »
I try thank you.
Offline Scrts
  • Country: lt
« Reply #54 on: January 08, 2017, 01:07:46 am »
Custom software  reads from ADXL345 register 0x00 what datasheet says: 0xE5 , so we were able easy connect to I2C devices from Orange Pi One powered by Armbian Linux  :-+
root@orangepione:/tmp# ./adxl345i2c
Device 0x53 (ADXL345 with ADO->GND) register: 0x00 data: 0xE5
So I understand that the pin mux is pre-selected to MUX3 by default? Did you also try to play with SPI?
Also what about debug? Can you debug remotely?
Thanks.
