Author Topic: Need example for linker script with overlays  (Read 1785 times)
Offline Postal2Topic starter
  • Country: ru
« on: July 05, 2024, 04:24:35 pm »
I hope not everyone programs only blink programs. I need to create some piece of program as an overlay, which is in ROM at startup, then loads into RAM and the program running in ROM calls functions from RAM.
Online brucehoult
Re: Need example for linker script with overlays
« Reply #1 on: July 05, 2024, 04:48:36 pm »
That's not an overlay. That's just a program section that lives in RAM, but is copied there from ROM at startup, just like the DATA section in every C program ever (initialised global variables).
  .itim :
    *(.itim)
    *(.itim*)
  } >ITIM AT> ROM
... where you have previously defined ITIM in the memory section with appropriate start address and size.
Then you just mark whatever functions you want with __attribute__(section("section name"))
Calls between ROM and ITIM and back just automagically work.
Complete example is included in e.g.
https://github.com/five-embeddev/riscv-scratchpad/blob/master/baremetal-startup-c/src/linker.lds
The following users thanked this post: SiliconWizard, Postal2
  • Country: ru
« Reply #2 on: July 05, 2024, 05:22:04 pm »
That is what I need. Thanks a lot. This is for Hitachi mcu with external rom, where I need to remove the external rom chip on the fly.
Online brucehoult
« Reply #3 on: July 06, 2024, 01:28:39 am »
Oh well, in that case just go through the entire linker script and change EVERY ">ROM" to ">some_RAM_area AT>ROM". Except the startup code itself...
  • Country: ru
« Reply #4 on: July 06, 2024, 02:18:29 am »
I write the downloadable part into a separate C file. So I can send the entire object file to the specified section. I still need to write a bufferless xmodem there.
  • Country: ru
« Reply #5 on: July 08, 2024, 03:56:31 am »
Working.
OUTPUT_ARCH(sh)
 ENTRY(_start)
 MEMORY
   itim (rwx) : o = 0xFFFFD000, l = 4k
   ram (rw) : o = 0xFFFFE000, l = 8k
   rom (rx) : o = 0x00000000, l = 256k
 SECTIONS
   .vects 0x00000000:
     _vects = .;
     *(.vects);
   } > rom
 .text 0x00000400 :
    CREATE_OBJECT_SYMBOLS
    *(EXCLUDE_FILE (*sci_mon.o) .text)
    etext = .;
 } > rom
 .init :
   *(.init)
 } > rom
 .fini :
   *(.fini)
 } > rom
 .got :
   *(.got)
   *(.got.plt)
 } > rom
 .rodata :
     *(.rodata)
    *(.rodata.*)
     _erodata = .;
 } > rom
_itim_start = .;
 .itim :
    _sciexec = .;
    sci_mon.o(.text)
    _esciexec = .;
 } > itim AT>rom
 .eh_frame_hdr :
    *(.eh_frame_hdr)
}> rom
.eh_frame :
    *(.eh_frame)
}> rom
.jcr :
    *(.jcr)
} > rom
 .tors :
     __CTOR_LIST__ = .;
     LONG((__CTOR_END__ - __CTOR_LIST__) / 4 - 2)
     ___ctors = . ;
     *(.ctors)
     ___ctors_end = . ;
     LONG(0)
    __CTOR_END__ = .;
     __DTOR_LIST__ = .;
    LONG((__DTOR_END__ - __DTOR_LIST__) / 4 - 2)
     ___dtors = . ;
    *(.dtors)
     ___dtors_end = . ;
     LONG(0)
     __DTOR_END__ = .;
    _mdata = .;
 } > rom
 .data : AT (_mdata) {
    _data = .;
    *(.data)
    _edata = .;
 } > ram
.gcc_exc :
    *(.gcc_exc)
} > ram
 .bss :
     _bss = . ;
     *(.bss)
     *(COMMON)
      _ebss = . ;
      _end = . ;
 } > ram
 .stack 0xFFFFFC00 :
    _stack = .;
    *(.stack)
 } >ram
 .stab . (NOLOAD) :
    [ .stab ]
 .stabstr . (NOLOAD) :
    [ .stabstr ]
 /DISCARD/ :
 *(.comment)
Online brucehoult
« Reply #6 on: July 08, 2024, 04:09:12 am »
At a glance, that looks to me that it will work on initial download, but not if you power the board off and back on again.
  • Country: ru
« Reply #7 on: July 08, 2024, 04:14:10 am »
It's working right now, in hardware.
I checked with "objdump -t a.out" before.
Start.s
!KPIT Infosystems Ltd, Pune, India. - 04-Dec-2001.
!This program is distributed in the hope that it will be useful,
!but WITHOUT ANY WARRANTY; without even the implied warranty of
!MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
! Start.s
.list
.section .text
.global _start  ! global Start routine
.extern _main
.extern _hw_initialise ! external Sub-routine to initialise Hardware
.extern _data
.extern _mdata
.extern _edata
.extern _stack
.extern _vects
_start:
! initialise the SP for non-vectored code
mov.l stack,r15
! call the hardware initialiser
mov.l hw_initialise,r1
jsr     @r1
nop
! initialise sections
mov.l edata,r1 ! edata in r1
mov.l mdata,r2 ! mdata in r2
mov.l data,r0         ! data in r0
cmp/eq  r0,r1
bt start_1
nop
start_l:
mov.b   @r2,r3  !get from src
mov.b   r3,@r0  !place in dest
add    #1,r2    !inc src
add    #1,r0    !inc dest
cmp/eq  r0,r1   !dest == edata?
bf start_l
nop
start_1:
! initialise itim
mov.l esciexec,r1 ! esciexec in r1
mov.l itim_start,r2 ! itim_start in r2
mov.l sciexec,r0 ! sciexec in r0
start_2:
mov.l   @r2,r3  !get from src
mov.l   r3,@r0  !place in dest
add    #4,r2    !inc src
add    #4,r0    !inc dest
cmp/hi  r0,r1   !dest == esciexec?
bt start_2
nop
mov.l main,r1
jsr     @r1
nop
.ALIGN 4
hw_initialise:
.long _hw_initialise
stack:
.long _stack
data:
.long _data
mdata:
.long _mdata
edata:
.long _edata
main:
.long _main
sciexec:
.long _sciexec
esciexec:
.long _esciexec
itim_start:
.long _itim_start
« Last Edit: July 08, 2024, 05:47:12 am by Postal2 »
  • Country: ru
« Reply #8 on: July 10, 2024, 04:32:58 am »
Reads internal firmware perfectly. If anyone is interested, I'll post the source code.
Offline peter-h
« Reply #9 on: July 10, 2024, 06:33:45 am »
Do a search here for e.g. a boot loader. I did this and posted a load of code. But it was STM, not Hitachi.
  • Country: ru
« Reply #10 on: July 11, 2024, 07:27:00 am »
... I did this ...
Okay.
I’ll try to come up with a trick and insert an overlay SH7047 flashing, 4kb RAM is definitely not enough, but the result will look beautiful. I understand about FDT, but if everything is already connected, why not write it at once.
  • Country: ru
« Reply #11 on: July 15, 2024, 10:22:18 pm »
Loading of vbr-register:
void vbr_set(unsigned int address)
unsigned int myvar = address;
__asm__("ldc r1,vbr;");
Interrupt handling:
void ram_int()
//reset errors?
__asm__("mov r14,r15;" "mov.l @r15+,r14;" "rte;" "nop;");
