Yep, its crap... MPLAB X is just terribly slow on my PC. It often gets confused and had non-stopping "parsing project xxxxx" messages, especially if I have several projects open at once.
I have a whole list of gripes but it does come down to being used to something like Visual Studio (there is a Linux version call "Visual Studio Code", I think, I've not used it).
Also because I'm working on PIC32MZ project almost exclusively in C++ (XC32 compiler is actually pretty good/modern thanks to is being gcc, the shipped std library I avoid though, I use ETLCPP
http://www.etlcpp.com) but the C++ support in MPLAB is essentially non-existent. Errors and warning constantly in the code that is actually perfectly fine..
Also don't get me started on Harmony.. Argh.. But that is another gripe altogether
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
(basically just don't is my advice).
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Once I get some time, I'll be reverting to manual Makefiles and XC32 directly I think.
Also I get very little use from the debugger - mostly it can't tell me anything, almost all variables I try to inspect are not found.. totally useless I think in my project. I have to debug using logging/pin toggling/'scope anyway so I'm not loosing anything and I'll be able to use an editor of my choice rather than the stuff in MPLAB X.
My suggestion: get familiar with the makefile flavour of your choice and use command line builds, then use what ever editor you find most comfortable
If you build a bootloader as the first part of your project, you then won't even need a PIC programmer much after that (assuming your device support self programming)...
Ash.
