Hi guys,
I'll try to resurrect this thread If I may.
I just got couple of SPO2 sensors from China. They were offered as "Compatible for Nellcor DS-100A Spo2 Sensor with Oximax Tech" and they are equipped with 9 pin DB9 female connector.
I managed to read their PROM using esp8266 nodeMcu board and sensor wired using previously mentioned connection - GND pin4 & DATA on pin8 of the DB9 connector. Despite they are both labeled with unique serial numbers, the data from their PROM is absolutely identical.
On the PROM request they both respond with following 8 bytes:
93 20 18 FF 0 0 60 51
Where 0x51 was confirmed by the OneWire.crc8() function to be correct.
It turns out the contents of the memory were also identical:
Data is[0000h]: DE E0 E4 64 60 62 60 A8 B2 86 0 2 2 3 4 4 1 FE 7 2 FF 2F 34 9 4 8B C8 E 7F 69 D4 21
Data is[0020h]: 92 31 2C C2 78 3D 30 D6 A2 69 2F 93 FF B5 CC EB B8 D6 A2 23 AB A5 B6 F5 6B 55 30 B0 BF A5 E1 76
Data is[0040h]: C0 C7 3E 9D 21 80 DE ED 43 7D B8 2B 9 F3 21 20 B 9A E6 C6 3E A7 C0 17 CA 14 EF 3A 5F CF ED DC
Data is[0060h]: C9 5E 50 EE 3 7E 68 B8 1E 15 65 C8 E8 7A ED D6 17 47 76 AE 40 C2 A6 2 BD 84 74 4 50 C 1A E
Data is[0080h]: 2 7 80 A7 86 FE 2C 92 64 96 9A AA 97 4B CC DB 5C DD 44 A2 41 4C 69 27 71 FF FF FF FF FF FF FF
Data is[00A0h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[00C0h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[00E0h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[0100h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[0120h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[0140h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[0160h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[0180h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[01A0h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[01C0h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Data is[01E0h]: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 3 0 0 FE FF FF FF FF FF 19 0 0 FE FF FF FF FF
So nothing to match the serials on the labels of the cables.
Unfortunately neither of the crc functions (crc8() & crc16) does not return the same code as the one red from the device:
Data is[0000h]: Calculated CRC8:8D
Data is[0000h]: DS250x -> CRC8:87
Data is[0020h]: Calculated CRC8:4C
Data is[0020h]: DS250x -> CRC8:21
Data is[0040h]: Calculated CRC8:16
Data is[0040h]: DS250x -> CRC8:77
Data is[0060h]: Calculated CRC8:D7
Data is[0060h]: DS250x -> CRC8:DD
Data is[0080h]: Calculated CRC8:A2
Data is[0080h]: DS250x -> CRC8:F
Data is[00A0h]: Calculated CRC8:63
Data is[00A0h]: DS250x -> CRC8:FF
Data is[00C0h]: Calculated CRC8:39
Data is[00C0h]: DS250x -> CRC8:FF
Data is[00E0h]: Calculated CRC8:F8
Data is[00E0h]: DS250x -> CRC8:FF
Data is[0100h]: Calculated CRC:D3
Data is[0100h]: DS250x -> CRC:FF
Data is[0120h]: Calculated CRC:12
Data is[0120h]: DS250x -> CRC:FF
Data is[0140h]: Calculated CRC:48
Data is[0140h]: DS250x -> CRC:FF
Data is[0160h]: Calculated CRC:89
Data is[0160h]: DS250x -> CRC:FF
Data is[0180h]: Calculated CRC:FC
Data is[0180h]: DS250x -> CRC:FF
Data is[01A0h]: Calculated CRC:3D
Data is[01A0h]: DS250x -> CRC:FF
Data is[01C0h]: Calculated CRC:67
Data is[01C0h]: DS250x -> CRC:FF
Data is[01E0h]: Calculated CRC:A6
Data is[01E0h]: DS250x -> CRC:FF
But you can see how memory contents affect the received crc8 code. Unfortunately I wasn't able to confirm those codes with the crc() functions no matter what I was trying. Still I can confirm that the data is identical on every read cycle.
I hope this will help.
So, having this information does anyone knows how all that memory contents are structured and how to extract calibration data?
Cheers!
