Author Topic: [Solved]-CH32V003 NOT RESETTING?  (Read 557 times)
Offline kgavionicsTopic starter
« on: July 06, 2024, 05:39:07 pm »
Hello
I have 2 boards based on the CH32V003, they are almost identical, except one has a push button and the other doesn't. I checked both boards pins PD7 (NRST) on the chip is connected to the PD7 on the board, but for some reason, on the first board (second board test start at 0:11 in the video) if I pull the PD7 down it resets and the second board doesn't. I flashed the same code on both, but I can't find any logical explanation why I can't have the external to work on the second board? Does someone have an idea what's going on here?
TIA
https://youtu.be/fu6yPqkV4j8
« Last Edit: July 06, 2024, 11:38:58 pm by kgavionics »
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
Re: CH32V003 NOT RESETTING?
« Reply #1 on: July 06, 2024, 07:46:01 pm »
Maybe one has the user option byte bits RST_MODE set to '11' to enable D7 as GPIO?
Look in the reference manual section 16.5
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
The following users thanked this post: kgavionics
« Reply #2 on: July 06, 2024, 10:57:31 pm »
Thank you rhodges, I think you are right! Now, I'm digging how to   erase the user option bytes.
Update:
I successfully, configured NRST PIN as NRST function using minichlink (https://github.com/cnlohr/ch32v003fun).
« Last Edit: July 06, 2024, 11:38:35 pm by kgavionics »
