Scenario: STM32F4 with lwIP and freeRTOS
This particular device is inside a safe environment, which must never have an internet connection. Protocol errors, e.g. due to lost UDP packets, will be handled by another layer.
One weak point of this whole setup is the variable CPU load lwIP generates. Normally we have sparse UDP exchanges, one telegram every second or so. At an higher packet rate, e.g. TFTP transfers, lwIP really starts eating into the available CPU bandwidth.
What I have been looking for, but couldn't find a good answer to, is: How could we go about limitting the CPU bandwidth that lwIP may eat up?
One idea that came to my mind, is monitoring CPU load (WWDG+EWI (Early Wakeup Interrupt)) and dynamically changing the priority of / disabling the ETH Interrupt. WWDG+EWI would be rather simple to add, since the device only uses IWDG so far.
Any comments or better of the shelf solutions that I didn't find / think of?
edit 2201301639: corrected typo in headline
