Author Topic: looking for an LC meter  (Read 6579 times)
Offline legacyTopic starter
« on: November 24, 2013, 05:14:00 pm »
looking for LC meter, my budget is up to $100
i'd like to have
ideal Inductance  range: 20uH .. 20mH
ideal Capacitance range: 200pF..200mF
any suggestion is welcome =)
« Last Edit: November 24, 2013, 05:41:02 pm by legacy »
Offline dannyf
Re: looking for an LC meter
« Reply #1 on: November 24, 2013, 05:23:03 pm »
ideal Inductance  range: 20uH .. 20KH
20KH? wow!
« Reply #2 on: November 24, 2013, 05:42:36 pm »
ops, fixed
what do you think about the LCR M4070 by mib_instruments ( ) ?
Offline Kohanbash
    • Robots for Roboticists
« Reply #3 on: November 24, 2013, 09:11:03 pm »
Hi
It does not meet your exact specs but this is a decent meter for the price
http://www.amazon.com/RSR-Electronics-Inc-Capacitance-Multimeter/dp/B00EJOBQQK/ref=sr_1_16?ie=UTF8&qid=1385327215&sr=8-16&keywords=rsr+multimeter
I have one that I use on occasion that I bought around  2004 that still works.
Good Luck
Robots for Roboticists Blog - http://robotsforroboticists.com/
Offline kripton2035
« Reply #4 on: November 24, 2013, 09:24:34 pm »
dont look anywhere else : unbeatable price/performance ratio here : $115 with shipping !
there are some sellers (from japan) that sell this device
take one with the crocodile and tweezers probes like this one :
http://www.ebay.com/itm/DER-EE-DE-5000-High-Accuracy-Handheld-LCR-Meter-with-TL-21-TL-22-JAPAN-NEW-/141116722439?pt=LH_DefaultDomain_0&hash=item20db364d07
I bought one a month ago and I'm very happy with it.
there are some threads on this forum about this device (and the original from IET)
« Last Edit: November 24, 2013, 09:28:50 pm by kripton2035 »
« Reply #5 on: November 25, 2013, 12:42:32 am »
thanks you!
DER-EE DE-5000 seems very pretty, i think it's ok for me
the price is "in budget with tolerance" and the ratio what_you_buy/what_you_pay_for seems excellent!
Offline true
  • INTERNET
« Reply #6 on: November 25, 2013, 03:08:32 am »
I like the DE-5000 so much, I have two of them :)
It's a great unit at $120, nothing can beat it at that price.
Offline mathsquid
  • I like math.
« Reply #7 on: November 25, 2013, 03:25:20 am »
What is the test signal level of the DE-5000?  Can it test capacitors in-circuit?
« Last Edit: November 25, 2013, 03:32:38 am by mathsquid »
« Reply #8 on: November 25, 2013, 09:07:55 am »
wandering if anyone has tested the LCR M4070 by mib_instruments, personally i think i am ordering DE-5000
Offline kripton2035
« Reply #9 on: November 25, 2013, 09:42:59 am »
test signal is 0.5V rms so ok for in circuit testing
I tried it on a pcb and it measures quite well in circuits capacitors.
but depending on circuit you can get wrong result : i.e. parallels capacitors.
Offline mathsquid
  • I like math.
« Reply #10 on: November 25, 2013, 12:58:50 pm »
I have an M4070 that I bought from mib_instruments, but I'm not sure what to tell you about it.  I've only had it a month and i haven't used it very much.  The numbers that it gives for capacitance and inductance are close (within a few percent), but not exactly the same as my ~$80 extech multimeter.  I'm not sure which is correct.
Offline dfmischler
« Reply #11 on: November 25, 2013, 01:28:41 pm »
May give bad readings with some semiconductors (e.g. Schottky diodes).
Offline kripton2035
« Reply #12 on: November 25, 2013, 02:11:11 pm »
not sure because 0.5V is with zero load
someone on the forum (robrenz ?) tested the real signal level and it was less than 100mV
« Reply #13 on: November 25, 2013, 03:25:03 pm »
here a review  ;D
« Reply #14 on: November 25, 2013, 03:29:29 pm »
and here it is the M4070 Manual (poor informations, anyway  :-// )
ok, about me, i have just ordered the DE-5000 from japan  :D
Offline seoiot123,
« Reply #15 on: November 28, 2013, 11:01:22 am »
thanks  for provide this lc meter information
Offline Jibby
« Reply #16 on: December 09, 2013, 11:37:49 am »
Available at that price in India
« Reply #17 on: December 09, 2013, 03:44:20 pm »
that's cool  ;D
i bought the full-kit, which means LCR meter plust PC kit, 130 euro shipped, it should arrive here (in italy) for xmass  :-+
« Reply #18 on: March 15, 2014, 09:36:01 pm »
what do you think about this toy ?
Online nctnico
« Reply #19 on: March 15, 2014, 10:50:50 pm »
I ordered one (from China). If it (XJW01 ?) does what it is supposed to do the price is very right. I'll do a small review when I get it. There are other sellers which show the PCB and an early prototype. It's nearly unnecessary to do a teardown  ;)
Another option is to get an AE20204:
http://www.ebay.com/itm/AE20204-High-Precision-LC-Meter-Kit-with-RS232-USB-Machined-Case-SMD-Tweezers-/261114894644
The AE20204 measures the resonance frequency which makes it less suitable for components with a low Q factor. The LCR meter should do better.
« Last Edit: March 15, 2014, 10:58:50 pm by nctnico »
