folks like me who tinker with writing/editing code on when we have to, and whose core competency is in other fields; libraries are god-send. I would be very interested to know what kind of validation they have done on their HAL libraries.
I dont se the point of this abstraction madness where a lib user has to do a call to a library just to wiggle a pin! Or abstracting
to death utterly simple things like systick who barely needs 3 register writes to be initialized, setup, and enabled and at the
same time they completely destroyed portability of code between devices by splitting up the systick definitions onto 3 different
files for one family of devices while for other devices continue to have systick neatly described in one file it is suposed to be
namely the definition file. And that for a function that is part of the ARM package and not ST. Same goes for NVIC but im not
100% sure on that one.(disclaimer if im all wrong).
Btw, systick is faster then NVIC because you have automatic reset of isr flag!
I dont mind one thick definition file nor many smal ones as long as they are written well. Im not against libraries or abstraction
per see, it's the way STM creating and managing the whole gorilla i'm against! What's worst of all ST is loosing money
by doing all those convoluted abstraction layers, and they don't realizing it , they believe they are "hipp" and modern
and trendy! As Clive described just imagine all the people needed to wrestle with this gorilla that now weights
200mega tonnes and in 5 years time when even more devices is added will weight 800Mtonnes +!
Everything boils down to bad management!
However there is one very god thing about this 200megaton abstracted low level gorilla. As it grows STM have to put on larger Flash and SRAM memories on the devices to compensate for the ever expanding bloat it creates. Something we on the dark side is quite pleased about! So yes, i have changed my mind, this new lib is actually great! Hohumm!
