myramfs: devname=myramfs, devstart=0x3000000, devlength=0x4000000
myramfs: Registered device myramfs from 49152KiB to 114688KiB
myramfs: Mapped from 0xc4180000 to 0xc8180000
myramswap: devname=myramswap, devstart=0x7000000, devlength=0x1000000
myramswap: Registered device myramswap from 114688KiB to 131072KiB
myramswap: Mapped from 0xc8200000 to 0xc9200000
these two kernel-modules are physical ram handlers.
in the dmesg:
- myramswap (/dev/myramdev2) has allocated ram, the MMU can't touch it, but it's not used.
- myramfs (/dev/myramdev1) has allocated ram, the MMU can't touch it, and it's used as ram-rootfs.
/dev/myramdev1 on / type ext2 (rw)
mpme on /dev/pts type devpts (rw)
/mnt/disk0 on /var type none (rw,bind)
/var/tmp on /tmp type none (rw,bind)
