Author Topic: Issue with chinese BLue Pill cks32f103c8t6  (Read 4488 times)
Offline EldarTopic starter
  • Country: az
« on: November 03, 2019, 01:45:02 pm »
I`ve got chinese clone CKS32f103c8t6 Blue Pill board with ST-LINK V2 (cheap clone again).I`m able to flash .hex file with ST LINK Utility software but I`m not able to use it with CubeIDE.Here is what I get when I press Debug Button:
Open On-Chip Debugger 0.10.0+dev-00021-g524e8c8 (2019-07-16-09:47)
Licensed under GNU GPL v2
For bug reports, read
   http://openocd.org/doc/doxygen/bugs.html
none separate
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 240 kHz
adapter_nsrst_delay: 100
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 240 kHz
Info : STLINK v2 JTAG v34 API v2 SWIM v7 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.201053
Info : Stlink adapter speed set to 240 kHz
Warn : UNEXPECTED idcode: 0x2ba01477
Error: expected 1 of 1: 0x1ba01477
in procedure 'init'
in procedure 'ocd_bouncer'
I`ve found that, some solved that issue by pasting this line to the some .cfg file on platformio IDE.
set _CPUTAPID 0x1ba01477
How could be this done on cubeIDE?
Thanks,
Eldar.
Offline dave j
Re: Issue with chinese BLue Pill cks32f103c8t6
« Reply #1 on: November 03, 2019, 02:57:56 pm »
Somewhere in your configuration it will reference a board configuration file for the blue pill called stm32f103_bluepill.cfg. You can add the set _CPUTAPID 0x1ba01477 to that file or, better, copy and edit file and use that.
You might need to change the interface to stlink-v2 instead of stlink-v2-1 as well.
I've attached the file I use. Remove the .txt extension (that's just to get it to work with the forum).
I'm not David L Jones. Apparently I actually do have to point this out.
  • Country: az
« Reply #2 on: November 03, 2019, 03:14:18 pm »
Thanks but I`m not able to find that file.U said somewhere in tghe configuration so I searched this address but didn`t find.
C:\ST\STM32CubeIDE_1.0.2\STM32CubeIDE\configuration
Offline dave j
« Reply #3 on: November 03, 2019, 03:22:12 pm »
The stm32f103_bluepill.cfg file is part of the OpenOCD installation.
In your IDE it will probably be selected when you configure which board you use. (I'm not familiar with CubeIDE.)
  • Country: az
« Reply #4 on: November 03, 2019, 05:10:00 pm »
I`m not familier with CubeIDE either :(
Offline SiliconWizard
« Reply #5 on: November 03, 2019, 10:45:53 pm »
You should probably beware of cheap chinese blue pills anyway. Just saying.
 :-DD
