Author Topic: PC PSU monitor with Arduino  (Read 1075 times)
Offline dawgTopic starter
« on: November 03, 2019, 01:41:49 am »
hi,
this is for a PC PSU monitor using an Arduino to monitor the
input levels.
The Nano gets power from the 5VSB rail from the PSU
i would like to have an amber led blinking to show the PSU
is on Standby but thats for later once I get the basics
sorted
so this is what happens:
PSU is on standby no leds are lit yet
press the PC on button and a green led lights up for 3 secs
then it goes off while the PC is booting
when the PC shuts down, 5v low input is read, a red led
lights up for 3 secs then goes off
all very simple but the code so far I have has GOTO and I
know thats frowned upon but its all I can do right now
the code works to display the analog input states but thats
about all it does.
any clues to what code is best used
I have tried all the arduino supplied examples but cant
decide which way the code would be best
Re: PC PSU monitor with Arduino
« Reply #1 on: November 03, 2019, 10:42:23 am »
here's a basic example of at least the flow cycle, but it doesn't light anything up when testing the input
instead of the 4 leds I opted to start again at 1 red and 1 green led
const int analogPin = A0;    // pin that the sensor is attached to
const int ledPin = 2;       // pin that the LED is attached to
const int ledPin2 = 3;       // pin that the LED2 is attached to
const int threshold = 850;   // arbitrary threshold level of analog input
void setup() {
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin2, OUTPUT);}
void loop() {
int analogValue = analogRead(analogPin);
loop2:
{goto low;}
loop1:
if(analogValue<threshold) {digitalWrite(ledPin2,HIGH);} //SHUTDOWN MP3
{digitalWrite(ledPin2,LOW);}
delay(333);
{if (analogValue>threshold){goto loop1;}
low:
if(analogValue<threshold) {goto loop2;} //this is to BYPASS the middle code
else if (analogValue>threshold){digitalWrite(ledPin,HIGH);}
delay (333);//pc on voice 3 sec DELAY
if (analogValue>threshold){digitalWrite(ledPin,LOW);}
delay (333);
 {goto loop1;}
Offline ozcar
« Reply #2 on: November 03, 2019, 06:18:56 pm »
In you code you refer to a “sensor” attached to A0, but you did not explain what you are really have connected there. Of course, you should not apply a voltage greater than the Arduino VCC, so you can't directly attach it to say the 12V output of the power supply. You could monitor the 3.3V or 5V outputs, but even there I would suggest including some series resistance in case something unexpected happens, say like you accidentally set the A0 pin to output mode.
In the code, I suggest defining two variables, one to represent the current power state (on or off) and the other the previous power state (also on or off) -  then you can check for a change, which it seems is what you want.
Something like this maybe:
bool PowerOn,PreviousPowerOn = false;
void setup()
void loop()
  PowerOn = analogRead(analogPin) > threshold;
  if ( !PreviousPowerOn && PowerOn )
    {  // power went on, turn on a LED for 3 seconds
      delay(3000);              // 3 sec DELAY
  if ( PreviousPowerOn && !PowerOn )
    {  // power went off, turn on another LED for 3 seconds
  // power did not change, do nothing.
  PreviousPowerOn = PowerOn;   // keep power state for next pass
If that does not work, try displaying the analogRead value, but given I have not tested it at all, anything is possible!
The following users thanked this post: dawg
« Reply #3 on: November 03, 2019, 09:46:03 pm »
ok thanks, I'll try this
« Reply #4 on: November 04, 2019, 02:16:05 am »
shit a brick that's awesome, it worked ! Brilliant mate
1 home
2 many thanks
3 goto home
cheers
