Author Topic: Issue building custom board with RP2040. (Board partially recognised by Windows)  (Read 4150 times)
Online SiliconWizard
Yes it's a 12V TVS so not that well adapted here. But note that regarding the highish capacitance (as it was mentioned earlier), it was unlikely the issue. The RP2040 is USB Full-Speed only and from the specs, you're allowed up to 100pF of capacitance on the data lines in FS (AFAIR) - actually you may sometimes see recommendations of adding some small capacitors on D+/D- for USB FS to limit EMI, although the series resistors should be enough for that purpose.
A very low capacitance is only required for USB HS and above.
Offline krho
  • Country: si
Seems that I forgot to connect B6 and B7 pins of the 16 pin USB C connector and hence, I think it contributes to the issue as well. I cannot possibly solder wires to it. So, I now have 2 queries, Since I have effectively designed the board in such a way that the USB C only works in one configuration of the cable, should I get rid of the SM712 and interchange the data lines?
You should connect A6 to B6 and A7 to B7. Then the connector will work both ways.
Offline atulraviTopic starter
  • Country: in
    • Personal Blog
Very interesting. In the next iteration, I shall consider some capacitors on the Data lines maybe.
Hardware builder, innovator, hobbyist, by night. Student by day. Amateur HAM radio operator (restricted) VU3FUJ.
  • Country: in
    • Personal Blog
[/quote]
So if I were to connect only A6 to B6, it should work in one direction alone right? (Considering the A7 is already connected and B6 is already connected)
Offline krho
  • Country: si
The following users thanked this post: atulravi
