Awesome! I will ship the current board to you, and you can take a look then!!
Thank you very much!!!
I will get your address on Private Messaging.
Hi dansku, the board arrived, got fixed and will hopefully go out with tomorrow's mail.
The main problem was the soldering of the USB connector. It had shorts and one pin didn't have solder. I noticed solder paste that didn't melt so I reflew it again and this fixed the shorts. Also, the board has some white crust, probably from the flux, that I never seen before and it didn't come off easily with IPA. I wonder what solder paste you use.
The 0.5mm QFN MCU was soldered OK. It's interesting that soldering the micro USB connector is more challenging than the QFN. This is also my experience. Never had a problem with the QFN.
I think you need to refine your reflowing process. I am not an expert but others may provide more information.
I have used elecrow 5mil metal stencils but oshstencils says that their plastic stencils can do 0.5mm pitch. I have on order two stencils 3mil and 5mil so will see how this will go. The plastic stencils are cheaper and arrives in the US in few days. Will see how it will go. Placing the paste with toothpick or syringe doesn't work well for me, stencils do.
