I think this is something most people would know the answer.
The problem in short, is that I have an array of numbers declared as volatile, aswell as a counter variable. I access these both, from a main loop and from a timer interrupt callback. The problem is that they seem to have different values on the main with respect to the interrupt. For example, if I add 1 for each call in the interrupt, and in the main I evaluate whether it is greater than a value (e.g if(counter>210) ), it never evaluates true, although it might evaluate true in the interrupt. You might skip reading the code and explanation, because
the question in particular is: how do you share an array between a function which is called in the main and another which is called in the interrupt, and why the values of these could seem different depending on what function they are found? I am using volatile.I want to know what I am missing, in order to learn more, because this challenges the understanding I have of volatile, although I have rarely used them. It seems to me that I have a misconception.
I posted my question in Adafruit forum too, but I might have asked in a confusing way, because I got no answers. I sometimes have a hard time making my questions understood in forums. Let me know if this is happening here.
This is the case in particular that I am dealing with: I want to make a sort of synthesizer. Reading the voltage of a potentiometer takes long enough to produce a sound glitch, so I need to make interrupts to keep up the audio writing. I intend to have a sound buffer shared among the main loop and the interrupt. In this way I can read potentiometers
The code might have a couple of unexplainable things, because I have been experimenting with it, but I tried to clean it up to make it understandable. This sketch is being "uploaded" using arduino to an Adafruit feather M4 board. I am also using code from the following repository to setup the interrupt:
https://github.com/Dennis-van-Gils/SAMD51_InterruptTimer. I have already made sure that the interrupt is indeed called.
I also hear a buzz, but that is likey to be due to some overlook that I might find later. I have seen it making sound without the buzz.
#include "Adafruit_ZeroI2S.h"
#include "SAMD51_InterruptTimer.h"
//if false, there will be sound, if true there is no sound (only
// a buzz of the buffering frequency)
//by toggling the LED I can make sure the interrupt is actually
//running at audio rate.
#define CONCURRENT false
#define SAMPLERATE_HZ 44100
#define AMPLITUDE ((1<<29)-1)
#define WAV_SIZE 256
#define BUFFERING_FREQUENCY 100
const uint32_t i2sIntervaluS = 20;
const uint32_t bufferSize = SAMPLERATE_HZ / BUFFERING_FREQUENCY;
volatile int32_t audioBuffer[bufferSize];
//variables used for the "circular" audio buffer
//indicates what part of the buffer has been written to the output
volatile uint32_t bufferPlayhead=0;
//indicates what part of the buffer has already been calculated
uint32_t bufferWritehead = 0;
#define F4_HZ 349.23
int32_t sine[WAV_SIZE] = {0};
// Create I2S audio transmitter object.
Adafruit_ZeroI2S i2s;
#define Serial Serial1
void generateSine(int32_t amplitude, int32_t* buffer, uint16_t length) {
// Generate a sine wave signal with the provided amplitude and store it in
// the provided buffer of size length.
for (int i=0; i<length; ++i) {
buffer[i] = int32_t(float(amplitude)*sin(2.0*PI*(1.0/length)*i));
audioBuffer[i] = int32_t(float(amplitude)*random(1.00));
uint32_t sineHead=0;
float freq=F4_HZ;
int32_t sample(){
//this will grow to be an expensive function
float floatSampleRate=float(SAMPLERATE_HZ);
float delta = (freq + 0) * WAV_SIZE/floatSampleRate;
uint16_t pos = uint32_t(sineHead*delta) % WAV_SIZE;
sineHead++;
return sine[pos];
//fill all the "spent" buffer with fresh new samples
void calculateBuffer(){
uint32_t tempBuffer[bufferSize];
uint32_t updateStart=bufferWritehead;
noInterrupts();
uint32_t updateEnd=bufferPlayhead % bufferSize;
interrupts();
//Imagine that the sample() function actually was more complicated,
//including the readout of analog data
while(bufferWritehead!=updateEnd){
tempBuffer[bufferWritehead]=sample();
bufferWritehead++;
bufferWritehead %= bufferSize;
//fast copy calculated buffer, not interruptible
//TODO: only copy the updated section of the buffer
noInterrupts();
for(uint32_t sampleNumber = updateStart; sampleNumber<updateEnd; sampleNumber++){
audioBuffer[sampleNumber]=tempBuffer[sampleNumber];
interrupts();
//actually send the sound out to I2S
void writeNextSample(){
digitalWrite(PIN_LED, true );
int32_t nspl=audioBuffer[bufferPlayhead % bufferSize];
// int32_t nspl=sine[bufferPlayhead % bufferSize];
i2s.write(nspl,nspl);
noInterrupts();
bufferPlayhead=bufferPlayhead+1;
interrupts();
digitalWrite(PIN_LED, false );
// when is time for next sample output (only concurrent false)
unsigned long nextWrite=0;
void setup() {
if (!i2s.begin(I2S_32_BIT, SAMPLERATE_HZ)) {
while (1);
i2s.enableTx();
generateSine(AMPLITUDE, sine, WAV_SIZE);
#if CONCURRENT
TC.startTimer(
i2sIntervaluS,
//floor(1000000 / float(SAMPLERATE_HZ)),
writeNextSample
#endif
void loop() {
unsigned long now=micros();
calculateBuffer();
#if !CONCURRENT
if(now>=nextWrite){
writeNextSample();
nextWrite=floor(float(now + 1000/SAMPLERATE_HZ));
#endif
