Hi there.
I tried posting this on the arduino forums too, but I think here is better.
I have the need to use an attiny85 chip on a i2c bus. It has to have both slave and master functionalities in the end, but it's not the issue now.
I used the
TinyWire library in order not to have to write everything from scratch, since its predecessor (TinyWireM for the master) worked fine and I used that a lot with tiny 8/45 chips.
Basically right now the net has only a Nano acting as a master, trying to call the tiny. And guess what: when the communication starts both SDA and SCK are pulled low and stay that way indefinitely. I tried:
- disconnecting the tiny: the bus works properly
- connecting other stuff on the bus, with or without the tiny but NOT calling the tiny: the bus works properly
So I suspect it's either a problem of the library (doubt it) or of my code (that's more like it), especially the "tiny" side.
Here is the "master" nano code:
#include <Wire.h>
void setup() {
Wire.beginTransmission(0x10);
Wire.endTransmission();
delay(1);
void loop() {
// put your main code here, to run repeatedly:
and the tiny code:
#include <TinyWire.h>
#include <avr/io.h>
#include <util/delay.h>
#include <stdint.h>
#define addr 0x10
volatile boolean startLed;
int main(){
TinyWire.begin(addr);
TinyWire.onReceive(onI2CReceive);
while(1)
if(startLed){
startLed=false;
// Do something later
return 0;
void onI2CReceive(){
startLed=true;
Please do mind that I tried sending data on the tiny and even putting a while inside the onI2CReceive function, reading the data, but nothing changed. This is the easiest failing example I can give.
So, what am I doing wrong here?
Cheers!
