I want to create my own stable IDE.I want to know how to do it???
Hi
If you want a 100% perfect IDE, you will need far more resources that you can afford. I suspect that a "from scratch" bug free IDE is probably well over a thousand man years of effort.
If you hire 100 guys for 10 years, you get an IDE. At this point it is perfect *and* it supports the parts that were out on the market 10 years ago. In those 10 years, you have had ample time to find all the errors in the manufacturer's data sheets. You also have been able to test a few thousand MCU's to find all of the places the silicon it's self has bugs.
Unless you either have a major budget, or are happy working on an IDE pretty much forever, this is not a road to go down. You will spend *far* less time working through the bugs in something like KDS (like by a factor of 1,000) than you will writing an IDE from scratch.
Down the road from us, there is an outfit that has taken a somewhat less ambitious approach. They decided to build their own IDE on top of Eclipse. Nothing super fancy. More an in-house customization than anything else. Last time I checked, they had five guys full time on supporting the effort. That's a lot of expense. For them it made sense. It lets them move designs between different vendors and *know* that the design will work. It eliminates the "tool chain lock in" that binds you to a specific vendor. They can grab an ARM from any of their vendors and swap the designs around.
So, can it be done - sure. Is it a lot of work - yes indeed it is. Do you need a pretty narrow scope to get it working any time soon? Most certainly.
The only rational way to go on Kinetics is KDS if you are doing this as a hobby. If you have a real budget, Kiel and IAR are both out there. They are dependent to some degree on the same "stuff" as KDS. That sort of reduces the advantage you get from them if "perfection" is your goal.
Bob
Bob
