Author Topic: Help needed to convert a code from one compiler to another for PIC mcu  (Read 975 times)
Offline khatusTopic starter
  • Country: gl
#include <18F4550.h>
#device adc=10
#device PASS_STRINGS = IN_RAM
#fuses NOMCLR, NOWDT, NOPROTECT, NOLVP ,NOBROWNOUT
#use delay (clock=20,000000)
#use i2c(Master,Fast=400000,sda=PIN_B0,scl=PIN_B1,force_sw) // maybe force_hw
#include <string.h>
#define OLED 0x78
#INCLUDE <stdlib.h>
const BYTE TEXT[51][5] =
   0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
   0x00, 0x00, 0x5F, 0x00, 0x00, // !
   0x00, 0x03, 0x00, 0x03, 0x00, // "
   0x14, 0x3E, 0x14, 0x3E, 0x14, // #
   0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
   0x43, 0x33, 0x08, 0x66, 0x61, // %
   0x36, 0x49, 0x55, 0x22, 0x50, //&
   0x00, 0x05, 0x03, 0x00, 0x00, // '
   0x00, 0x1C, 0x22, 0x41, 0x00, // (
   0x00, 0x41, 0x22, 0x1C, 0x00, //)
   0x14, 0x08, 0x3E, 0x08, 0x14, // *
   0x08, 0x08, 0x3E, 0x08, 0x08, // +
   0x00, 0x50, 0x30, 0x00, 0x00, //,
   0x08, 0x08, 0x08, 0x08, 0x08, // -
   0x00, 0x60, 0x60, 0x00, 0x00, // .
   0x20, 0x10, 0x08, 0x04, 0x02, // /
   0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
   0x04, 0x02, 0x7F, 0x00, 0x00, // 1
   0x42, 0x61, 0x51, 0x49, 0x46, // 2
   0x22, 0x41, 0x49, 0x49, 0x36, // 3
   0x18, 0x14, 0x12, 0x7F, 0x10, // 4
   0x27, 0x45, 0x45, 0x45, 0x39, // 5
   0x3E, 0x49, 0x49, 0x49, 0x32, // 6
   0x01, 0x01, 0x71, 0x09, 0x07, // 7
   0x36, 0x49, 0x49, 0x49, 0x36, // 8
   0x26, 0x49, 0x49, 0x49, 0x3E, // 9
   0x00, 0x36, 0x36, 0x00, 0x00, // :
   0x00, 0x56, 0x36, 0x00, 0x00, //;
   0x08, 0x14, 0x22, 0x41, 0x00, // <
   0x14, 0x14, 0x14, 0x14, 0x14, // =
   0x00, 0x41, 0x22, 0x14, 0x08, // >
   0x02, 0x01, 0x51, 0x09, 0x06, // ?
   0x3E, 0x41, 0x59, 0x55, 0x5E, // @
   0x7E, 0x09, 0x09, 0x09, 0x7E, // A
   0x7F, 0x49, 0x49, 0x49, 0x36, // B
   0x3E, 0x41, 0x41, 0x41, 0x22, // C
   0x7F, 0x41, 0x41, 0x41, 0x3E, // D
   0x7F, 0x49, 0x49, 0x49, 0x41, // E
   0x7F, 0x09, 0x09, 0x09, 0x01, // F
   0x3E, 0x41, 0x41, 0x49, 0x3A, // G
   0x7F, 0x08, 0x08, 0x08, 0x7F, // H
   0x00, 0x41, 0x7F, 0x41, 0x00, // I
   0x30, 0x40, 0x40, 0x40, 0x3F, // J
   0x7F, 0x08, 0x14, 0x22, 0x41, // K
   0x7F, 0x40, 0x40, 0x40, 0x40, // L
   0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
   0x7F, 0x02, 0x04, 0x08, 0x7F, // N
   0x3E, 0x41, 0x41, 0x41, 0x3E, // O
   0x7F, 0x09, 0x09, 0x09, 0x06, // P
   0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
   0x7F, 0x09, 0x09, 0x09, 0x76  // R
const BYTE TEXT2[44][5]=
   0x26, 0x49, 0x49, 0x49, 0x32, // S
   0x01, 0x01, 0x7F, 0x01, 0x01, // T
   0x3F, 0x40, 0x40, 0x40, 0x3F, // U
   0x1F, 0x20, 0x40, 0x20, 0x1F, // V
   0x7F, 0x20, 0x10, 0x20, 0x7F, // W
   0x41, 0x22, 0x1C, 0x22, 0x41, // X
   0x07, 0x08, 0x70, 0x08, 0x07, // Y
   0x61, 0x51, 0x49, 0x45, 0x43, // Z
   0x00, 0x7F, 0x41, 0x00, 0x00, // [
   0x02, 0x04, 0x08, 0x10, 0x20, // \
   0x00, 0x00, 0x41, 0x7F, 0x00, // ]
   0x04, 0x02, 0x01, 0x02, 0x04, // ^
   0x40, 0x40, 0x40, 0x40, 0x40, // _
   0x00, 0x01, 0x02, 0x04, 0x00, // `
   0x20, 0x54, 0x54, 0x54, 0x78, // a
   0x7F, 0x44, 0x44, 0x44, 0x38, // b
   0x38, 0x44, 0x44, 0x44, 0x44, // c
   0x38, 0x44, 0x44, 0x44, 0x7F, // d
   0x38, 0x54, 0x54, 0x54, 0x18, // e
   0x04, 0x04, 0x7E, 0x05, 0x05, // f
   0x08, 0x54, 0x54, 0x54, 0x3C, // g
   0x7F, 0x08, 0x04, 0x04, 0x78, // h
   0x00, 0x44, 0x7D, 0x40, 0x00, // i
   0x20, 0x40, 0x44, 0x3D, 0x00, // j
   0x7F, 0x10, 0x28, 0x44, 0x00, // k
   0x00, 0x41, 0x7F, 0x40, 0x00, // l
   0x7C, 0x04, 0x78, 0x04, 0x78, // m
   0x7C, 0x08, 0x04, 0x04, 0x78, // n
   0x38, 0x44, 0x44, 0x44, 0x38, // o
   0x7C, 0x14, 0x14, 0x14, 0x08, // p
   0x08, 0x14, 0x14, 0x14, 0x7C, // q
   0x00, 0x7C, 0x08, 0x04, 0x04, // r
   0x48, 0x54, 0x54, 0x54, 0x20, // s
   0x04, 0x04, 0x3F, 0x44, 0x44, // t
   0x3C, 0x40, 0x40, 0x20, 0x7C, // u
   0x1C, 0x20, 0x40, 0x20, 0x1C, // v
   0x3C, 0x40, 0x30, 0x40, 0x3C, // w
   0x44, 0x28, 0x10, 0x28, 0x44, // x
   0x0C, 0x50, 0x50, 0x50, 0x3C, // y
   0x44, 0x64, 0x54, 0x4C, 0x44, // z
   0x00, 0x08, 0x36, 0x41, 0x41, //{
   0x00, 0x00, 0x7F, 0x00, 0x00, //|
   0x41, 0x41, 0x36, 0x08, 0x00, //}
   0x02, 0x01, 0x02, 0x04, 0x02 // ~
int DISPLAY [1024];
void OLED_command(int ind, int com)
   i2c_start ();
   i2c_write (ind);
   i2c_write (0x00);
   i2c_write (com);
   i2c_stop ();
void OLED_write(INT ind)
   LONG i;
   OLED_command (ind, 0x21) ;
   OLED_command (ind, 0x00);
   OLED_command (ind, 127);
   OLED_command (ind, 0x22) ;
   OLED_command (ind, 7);
   i2c_start ();
   i2c_write (ind) ;
   i2c_write (0x40) ;
   FOR (i = 0; i < 1024; i++)
      i2c_write (DISPLAY[i]) ;
   i2c_stop ();
void  OLED_init(INT add)
   OLED_command (add, 0xae) ;
   OLED_command (add, 0xa8);
   OLED_command (add, 0x3f);
   OLED_command (add, 0xd3);
   OLED_command (add, 0x00);
   OLED_command (add, 0x40);
   OLED_command (add, 0xa0);
   OLED_command (add, 0xa1);
   OLED_command (add, 0xc0);
   OLED_command (add, 0xc8);
   OLED_command (add, 0xda);
   OLED_command (add, 0x12);
   OLED_command (add, 0x81);
   OLED_command (add, 0xfF);
   OLED_command (add, 0xa4);
   OLED_command (add, 0xa6) ;
   OLED_command (add, 0xd5);
   OLED_command (add, 0x80);
   OLED_command (add, 0x8d);
   OLED_command (add, 0x14) ;
   OLED_command (add, 0xAF) ;
   OLED_command (add, 0x20) ;
   OLED_command (add, 0x00) ;
void OLED_pixel(LONG x,long y)
   LONG nt;
   LONG pagina;
   LONG bit;
   pagina = y /8;
   bit= y-(pagina*8);
   nt= DISPLAY[pagina*128+x];
   nt |= 1 << bit;
   DISPLAY[pagina*128+x] = nt;
   Void OLED_text(int x, int y, char *textptr, int size)
      int i, j, k, l, m;     // Loop counters
      BYTE pixelData[5];     // Stores character data
      for (i = 0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
         if (textptr[i] < 'S') // Checks if the letter is in the first text array
            memcpy (pixelData, TEXT[textptr[i] - ' '], 5) ;
         else if (textptr[i] <= '~') // Check if the letter is in the second array
            memcpy (pixelData, TEXT2[textptr[i] - 'S'], 5) ;
         else
         memcpy (pixelData, TEXT[0], 5); // DEFAULT to space
         if (x + 5 * size >= 128)  // Performs character wrapping
            x = 0;       // Set x at far left position
            y += 7*size + 1;    // Set y at next position down
         for (j = 0; j<5; ++j, x += size)  // Loop through character byte data
            for (k = 0; k<7 * size; ++k)  // Loop through the vertical pixels
               if (bit_test (pixelData[j], k)) // Check if the pixel should be set
                  for (l = 0; l<size; ++l) // The next two loops change the
                     // character's size
                     for (m = 0; m<size; ++m)
                        OLED_pixel (x + m, y+k * size + l); // Draws the pixel
   VOID OLED_clear()
      LONG x;
      FOR (x = 0; x < 1024; x++)
         DISPLAY[x] = 0x00;
   void main()
      char txt[100];
      OLED_init(OLED);
      int16 value;
      setup_adc_ports(AN0);
      setup_adc(ADC_CLOCK_DIV_64);
      set_adc_channel(0);
      char str[20];
      WHILE (1)
         OLED_clear();
         delay_us(12);
         value = read_adc();
         sprintf(str, "%lu", value);
         sprintf(txt,str);
         OLED_text(0,16,"Voltage",2);
         OLED_text(82,16,txt,2);
         OLED_text(0,33,"Current",2);
         OLED_text(82,33,txt,2);
         OLED_text(0,50,"Power",2);
         OLED_text(82,50,txt,2);
         OLED_write(OLED);
         delay_ms(300);
This was the code that i found in CCSC forum for OLED 128x64 SSD1306 I2C display. But now i want to convert it to mikroC for pic.But i am a programming expert.Can anyone in this group help me to convert it from CCS to mikroc for pic??
Offline MarkF
Do you want to keep it as I2C or use SPI?
I wrote a library for a SSD1351 OLED (128x96) that uses SPI that would probably work with minor changes.
It writes directly to the display memory so you don't need MCU RAM.
« Last Edit: October 23, 2020, 04:07:02 am by MarkF »
  • Country: gl
I want to keep it as I2C. But how can i use it in my code??
Offline Nerull
You need to replace the i2c and and adc functions from CCS and use the equiavlent functions from the mikroc library, or just write the registers directly.
https://download.mikroe.com/documents/compilers/mikroc/pic/help/i2c_library.htm
https://download.mikroe.com/documents/compilers/mikroc/pic/help/adc_library.htm
  • Country: gl
#include <stdint.h>
#include <string.h>
#define OLED 0x78
#include <stdlib.h>
const char TEXT[51][5] =
const char TEXT2[44][5]=
int DISPLAY [1024];
   I2C1_Start();
   I2C1_Wr(ind);
   I2C1_Wr(0x00);
   I2C1_Wr(com);
   I2C1_Stop();
void OLED_write(int ind)
   long i;
   I2C1_Start();
   I2C1_Wr(ind) ;
   I2C1_Wr(0x40) ;
   for (i = 0; i < 1024; i++)
      I2C1_Wr(DISPLAY[I]) ;
   I2C1_Stop();
void  OLED_init(int add)
void OLED_pixel(long x,long y)
   long nt;
   long pagina;
   long bi_t;
   pagina = y /8;
   bi_t= y-(pagina*8);
   nt |= 1 << bi_t;
      byte pixelData[5];     // Stores character data
      for (i = 0; textptr[I] != '\0'; ++i, ++x) // Loop through the passed string
         if (textptr[I] < 'S') // Checks if the letter is in the first text array
            memcpy (pixelData, TEXT[textptr[I] - ' '], 5) ;
         else if (textptr[I] <= '~') // Check if the letter is in the second array
            memcpy (pixelData, TEXT2[textptr[I] - 'S'], 5) ;
         else
                     // character's size
   VOID OLED_clear()
      long x;
      for(x = 0; x < 1024; x++)
         DISPLAY[x] = 0x00;
   void main()
      char txt[100];
      OLED_init(OLED);
      char str[20];
      while (1)
         OLED_clear();
         delay_us(12);
         OLED_write(OLED);
         delay_ms(300);
It shows the following error
Offline MarkF
I would need to study the datasheet to see how different the commands are since the the SSD1306 is B/W and the SSD1351 is color.
The SPI in my library is pretty confined and would need to be replaced with I2C commands.
In OLED.h:
   Change the PIC assignment pins
   Replace SSD1351 command definitions
See in OLED.c:
   oledCmd()
   oledDat()
   oledSetup()
   oledClear()
   oledHorizLine()
   oledVertLine()
   oledRectFill()
The SPI commands are basically repeated in each.  So, when you convert one to I2C, you just cut-and-paste all the others.
The oledSetup() would probably be hit the hardest.
I'm guessing the color to B/W could just be modifying the ORGB() function to do gray scale.
I wouldn't mind having a SSD1306 B/W library if you're not in a hurry and can wait for me to make the changes.
F.Y.I.  I have not done I2C but it's on my TODO list.
Edit-  I use MPLAB X and XC8
You can take a look at the Adafruit code but it's not for a PIC.  https://github.com/adafruit/Adafruit_SSD1306
« Last Edit: March 27, 2019, 04:08:42 pm by MarkF »
