Author Topic: Help Needed To Set Clocks with PIC16F18456..I'm totally confused!  (Read 1283 times)
Offline Salome2Topic starter
The 16F18456 seems to have so many clock settings.
The attached RefClkEnigma shows Fosc as a clock source when Fosc  is always turned off in sleep!
In particular, I want to use the Reference Clock for the clock for TMR1 because it will still run in SLEEP mode.
If I set TMR1CLk to Fosc or Fosc/4 system clock, TMR1 works as expected, but when I switch the setting to Reference Clock I get a clock that quits after about a minute..just stops!
From what I see on my scope, I seem to have set Fosc to 64mHz!
I need help setting up an internal clock source for TMR1 to work at highest speed in sleep mode.
//-------------------------------Configuration Words-----------------------------------
#pragma config CLKOUTEN=1        //CLKOUT is Disabled
#pragma config FEXTOSC=4         //External Osc Disabled
#pragma config RSTOSC=0          //HFINTOSC 32MHz  startup osc
void Init_TMR1()
{ // TIMER1 overflows at 65536 clocks
  T1CKPS0=1;        // Set TMR1 prescaler 1:8 HFINTOSC
  T1CKPS1=1;        // 0x11 = 1/8 Prescaler
  TMR1CLK=0x01000;  // Reference Clock Output(stays awake during sleep)
  CLKRCON=0b10010000; //HFINTOSC
  CLKRCLK=0b00000001; //RefClk 50%DC No prescale
  T1CONbits.RD16=1;       // 16-bit read and write of TMR1 doesn't work?
  TMR1IF = 0;                   // clear TIMER1 interrupt request
  TMR1IE = 0;                   // disable TIMER1 interrupt
  PEIE   = 1;                     // enable peripheral interrupts
  TMR1ON = 0;                // Disable TMR1 until started by bell detection routine
  TMR1H  = 0;
  TMR1L  = 0;
void Init_PIC()
  OSCCON1=0x10;   //32-MHz 2xPLL of 16MHz HFINTOSC  (bits 0-3 are Clk Div)
  OSCFRQ =0x110;  //16Mhz HFINTOSC selected to feed 2x PLL
  HFOEN  =1;           //HFINTOSC explicitly on
  PEIE  = 1;
I have attached copies of the specsheet pages applicable to setting up clocking.
« Last Edit: October 08, 2024, 03:08:52 am by Salome2 »
Offline NorthGuy
Re: Help Needed To Set Clocks with PIC16F18456..I'm totally confused!
« Reply #1 on: October 07, 2024, 03:57:20 pm »
The timer is not an independent clock source. It simply counts pulses of an underlying clock source. If the underlying clock source stops, the timer stops too.
The following users thanked this post: Salome2
« Reply #2 on: October 07, 2024, 05:27:23 pm »
NorthGuy, Thanks, but I know that a timer doesn't work without an oscillator clock source. I just stated my question poorly, but I have edited my opening post and fixed that path to misunderstanding.
With the 16F18456, there are a lot of possible settings (and  not so obvious missteps) to setting up clocks and oscillators.
My Question: What am I doing wrong in configuring the Reference Clock for Timer1?
Is the code below at fault?
      OSCFRQ =0x110
Is the CONFIG 1 setting wrong?
Is my TMR1 clock setup for the Reference Clock source wrong?
  T1CKPS0=1;        // Set TMR1 prescaler 1:2 HFINTOSC
« Last Edit: October 07, 2024, 05:46:52 pm by Salome2 »
Online SiliconWizard
« Reply #3 on: October 07, 2024, 10:20:53 pm »
      OSCFRQ =0x110
Yes. The value for OSCFRQ is wrong. I think you got confused between values in hex and values in binary. OSCFRQ is an 8-bit register with only bits 2:0 used. 0x110 is a hex literal requiring 9 bits. With this value, it actually sets  bits 2:0 to all 0, which is a reserved value.
The correct value for a 16 MHz frequency for HFINTOSC (which will give 32 MHz with the 2xPLL option) is 101 (binary), so 5 in decimal or 0x05 if you prefer hex.
So that should be:
OSCFRQ = 0x05
It appears correct. Note that for RSTOSC, this defines the startup config. But you change it later on to 2x PLL, so this setting could be also 1, or 6 (slower) or even 5 (slower yet). Doesn't really matter as long as you use an internal oscillator, the oscillator will be reconfigured when you set  OSCCON1 and OSCFRQ.
Also note that there are two ways of setting 32 MHz from HFINTOSC. Either directly, or via the 2x PLL (the latter being what you set with OSCCON1 and OSCFRQ). There is no 64 MHz setting possible from HFINTOSC.
You seem to have again mixed hex literals with binary for TMR1CLK. '0x' prefix is hex, '0b' is binary. So, another thing to fix.
'TMR1CLK=0x01000' will actually set 0 to TMR1CLK.
You seem to have swapped the comments for CLKRCON and CLKRCLK.
CLKRCLK sets the clock source, CLKRCON set the base divider and duty cycle. Other than comments, the values seem correct here.
« Last Edit: October 07, 2024, 10:22:38 pm by SiliconWizard »
The following users thanked this post: Salome2, Dazed_N_Confused
« Reply #4 on: October 07, 2024, 10:56:40 pm »
SiliconWizard, I seem to be more of a Germanium Goof!   I didn't realize how bad my misunderstanding of hex, binary and literals are.
Thank you so much for helping me out and pointing out my coding has such beginner's errors.
« Last Edit: October 07, 2024, 11:03:56 pm by Salome2 »
« Reply #5 on: October 07, 2024, 11:22:22 pm »
Does it work now?
Offline NorthGuy
« Reply #6 on: October 07, 2024, 11:47:11 pm »
You don't need to manipulate OSCCON. The chip will set it to 32 MHz for you once you configured RSTOSC. You only need to do this if you want to switch clock frequency in run time. But, this sets the CPU clock - FOSC - which is shut down during sleep no matter what it is. Hence these settings don't matter during sleep.
If you want to use something during sleep, you need to run it from one of the oscillators, not from FOSC. The highest frequency would be HFINTOSC (High Frequency Internal Oscillator), with the frequency regulated by OSCFRQ register up to 32 MHz. However, the faster you run it, the more energy it consumes.
If you also run CPU from HFINTOSC (as you do), the HFINTOSC's frequency will affect the CPU as well.
« Reply #7 on: October 08, 2024, 01:33:13 am »
SiliconWizard, Thanks for your valuable attention.
I changed:
 OSCFRQ=0x110;           0x110--------> =6;
 OSCCON1=0x10;           0x10---------> =2;
 TMR1CLK=0x01000;      0x01000 ----> =8;
Unfortunately the ship yet does not stay afloat.  TMR1  flatlines after about 10-secs now!
« Last Edit: October 08, 2024, 02:28:53 am by Salome2 »
« Reply #8 on: October 08, 2024, 02:00:11 am »
Thanks NorthGuy for the heads up! I will switch frequencies.
My Bubba method to identify a consistently fixed waveform doorbell tone is to put everything to sleep except Cmp1 (comparator) to detect a tone burst.
At the start of doorbell tone burst, amplitude detection by CMP1 triggers C1IF and this must wake up the system and TMR1 must startup to record the raw value TMR1 counts of Cmp1 Interrupt triggers and store each value in an integer array to be analyzed after 65535 TMR1 counts ends the sampling period.
So, the Reference Clock is only required to provide a high speed clock for Cmp1 while the MCU sleeps, awaiting a doorbell ring sound.
« Last Edit: October 08, 2024, 02:25:09 am by Salome2 »
Offline NorthGuy
« Reply #9 on: October 08, 2024, 03:39:33 am »
By your description, it doesn't sound like you need a timer during sleep because you start it only upon wakeup.
The Reference Clock is a clock divider which takes an existing clock and produces a different lower frequency clock. It is of no use to you.
The following users thanked this post: SiliconWizard, Salome2
« Reply #10 on: October 08, 2024, 04:19:25 pm »
NorthGuy, thanks for pointing out to me the the Reference Clock is not needed.
All I need to use is HFINTOSC with prescalers when appropriate. I had the wrong idea that HFINTOSC was  turned off during sleep.
I still have bad clock setup and I must go back and  study the specsheet again to try to understand what I am attempting to do!
« Last Edit: October 09, 2024, 11:11:45 am by Salome2 »
« Reply #11 on: October 09, 2024, 11:11:56 am »
Update, now getting to clearly understand how to set clock resources and how code can request a clock freq. change and pole status regs to know when the freq. change is complete.
My biggest problem was confusing 0x with 0b which allowed me to make absurd clock and TMR1 settings and yet wonder why things were working truly screwy.
i went back to studying the specsheet again to finally have a clear understanding of the simplified TMRx and Osc block diagrams.
Many more thanks to SiliconWizard and NorthGuy!
