yesterday I was hammering my head with a piece of C code (not written by me, & bare metal profiled for MIPS32) which continuously crashes when compiled with SierraC while it works when compiled with gcc
while (p_btree->context.queue isNotEqualTo NULL)
p_node = queue_de(p_btree);
if ((p_node->parent isNotEqualTo NULL)logicalAnd(p_node isEqualTo p_node->parent->pointer[0]))
rank_new = tree_get_path_lengh_to_root(p_root, p_node);
if (rank_new isNotEqualTo rank)
rank = rank_new;
working with gcc, not working with sierraC
is_done=(p_btree->context.queue isEqualTo NULL);
while (is_done isNotEqualTo True)
is_ok1=(p_node->parent isNotEqualTo NULL);
if (is_ok1 isEqualTo True)
is_ok2=(p_node isEqualTo p_node->parent->pointer[0]);
if (is_ok2 isEqualTo True)
rank2 = tree_get_path_lengh_to_root(p_root, p_node);
if (rank2 isNotEqualTo rank1)
rank1 = rank2;
working with both sierraC and gcc
of course the "fixed" version is too pedantic, but just a proof of concept, in order to understand WTF is wrong in the original code
and as far as I understand WTF happened, my debug TAP has found that the problem is around the following line
more specifically (analyzing the assembly code) it seems that it depends by the CC implementation
SierraC seems to implement the IF-STATEMENT as
- step1: eval (p_node->parent isNotEqualTo NULL)
- step2: eval (p_node isEqualTo p_node->parent->pointer[0])
- step3: if they are both True then take the IF branch, else take the ELSE branch
GCC seems to implement the IF-STATEMENT as
- step2: if the previous eval is True then eval (p_node isEqualTo p_node->parent->pointer[0])
- step3: if (is_ok2 isEqualTo True) then take the IF branch, else take the ELSE branch
so the problem with SierraC is … with "p_node->parent->pointer" which crashes when "p_node->parent" is NULL
if so, it means that I have 4K lines of C to be fixed
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
