Author Topic: Looking for professionals who use advanced encryption modules and SSL communicat  (Read 297 times)
Offline em_elsaTopic starter
  • Country: cn
Looking for professionals who use advanced encryption modules and SSL communication in 32-bit MCUs and are familiar with the use of libraries such as mbedtls.
Offline radiolistener
  • Country: ua
What is your question?
I didn't worked with SSL on MCU, but some time ago implemented some custom TLS stack with specific requirements on a client side.
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Mongoose has a built-in TLS1.3 stack.
https://mongoose.ws/documentation/#built-in-tls13-stack
Have not used that feature, but I use Mongoose professionally and enjoy working with it.
“They Don’t Think It Be Like It Is, But It Do”
Offline peter-h
I have finished a project which contains MbedTLS. It has HTTPS client which uses this.
A huge chunk of code, over 200k (32F417) but does seem to work. TLS is difficult to integrate; connects to LWIP in this case which also works.
What input are you specifically looking for? You must have a specific use case for TLS, because embedded (IoT) devices on open ports, for public access, are a really bad idea. See past threads on this, and a "wide variety of views".
