Author Topic: Fluke 19X/B/C/II Firmware to Binary converter  (Read 2172 times)
Offline patpatTopic starter
« on: August 14, 2017, 03:47:03 pm »
FlukeFW2Bin.exe takes the firmware file (Tetra.ldf, or data.bin) from within Fluke's FlashTool
(F190_II_V11.44.exe, FlashTool_19xC_2xC_V804.exe, FlashTool_F190C_V615.exe, etc.)
and converts it into 2 binary files for analysis purposes.
The firmware on these Fluke Scopes uses the Nucleus PLUS - Version CL7111A  RTOS what means
the uP is some form of ARM little-endian CL7111A probably similar to CIRRUS LOGIC CL-PS7111
The produced files binary must be loaded at 0x40000000 and 0x44000000
Entry point 0x40000080
Best,
Pat
Offline Assafl
Re: Fluke 19X/B/C/II Firmware to Binary converter
« Reply #1 on: August 14, 2017, 05:11:38 pm »
Since all of these use the same hardware - can a B version be converted to a C version?
« Reply #2 on: August 14, 2017, 09:28:22 pm »
Well the displays are essentially different but I do not know about the bandwidth differences.
At the moment I just looked a bit at the code related to the undocumented console commands.
EO ?
EX ?  Check Memory
FM ?
GD   GET DOWN
GL   GO TO LOCAL
GR   GO TO REMOTE
HO   HOLD
ID   IDENTIFICATION
IM ?
IS   INSTRUMENT STATUS
KY ?
PC   PROGRAM COMMUNICATION
PS   PROGRAM SETUP
PW ?
QC ?
QI ?
QM   QUERY MEASUREMENT
QP   QUERY PRINT
QS   QUERY SETUP
QW   QUERY WAVEFORM
RB ?
RC ?
RD   READ DATE
RI   RESET INSTRUMENT
RN ?
RP   REPLAY
RS   RECALL SETUP
RT   READ TIME
RW ?
SO   SWITCH ON
SS   SAVE SETUP
ST   STATUS QUERY
TA   TRIGGER ACQUISITION
VE ?
WB ?
WC ?
WD   WRITE DATE
WT   WRITE TIME
WW ?
EXTENSION COMMAND TABLE (RAM 0x444000000)
CF ?
EO ?
FC ?
PF ?
QF ?
TI ?
FP ?
Offline Assafl
« Reply #3 on: August 14, 2017, 09:47:41 pm »
In the service manual Fluke states that the specific model is set when the main board is replaced. It can only be done at a Fluke service center.
My guess is that the run a console setup or modify an identification string.
The screen is just color. But it may be that a BW screen will be unreadable if the output is color.
Thanks for figuring out the console commands.
Offline lostking2008
« Reply #4 on: August 13, 2020, 09:11:01 pm »
Does anyone know how to run the FlukeFW2Bin.exe utility, things like OS environment, commands, etc.? It does not come with any guide or readme.txt in the zip package.
Thanks,
Ken
