Hardware: Heltec Wifi 32 LoRa V2
Platform: PlatformIO/Arduino
I've gone a day and a half at this one so far. I managed to make things work with light sleep, but not deep sleep. What i am trying to do is to put the ESP32 into deep sleep mode and have it wake on GPIO26 (LoRa rx,tx complete), in other words, i want the SX1276 to listen for and inform the ESP32 of a new incoming message while the ESP32 is in deep sleep. First i'll share the code that is working (with light sleep):
#include "Arduino.h"
#include "heltec.h"
#define BAND 915E6 //you can set band here directly,e.g. 868E6,915E6
String packSize = "--";
String packet;
void cbk(int packetSize) {
packet = "";
packSize = String(packetSize,DEC);
for (int i = 0; i < packetSize; i++) {
packet += (char) LoRa.read();
Serial.println(packet);
void setup() {
Heltec.begin(false /*DisplayEnable Enable*/, true /*Heltec.Heltec.Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
LoRa.receive();
delay(10);
gpio_wakeup_enable(GPIO_NUM_26, GPIO_INTR_HIGH_LEVEL);
esp_sleep_enable_gpio_wakeup();
void loop() {
esp_light_sleep_start();
Serial.println("Incoming Message");
int packetSize = LoRa.parsePacket();
if (packetSize) {
cbk(packetSize);
LoRa.receive(); // Evidently the LoRa radio has to be put back into continuous recieve mode \
after waking up the ESP32 from sleep, otherwise it will not raise DIO0 to \
which indicates RX is done (new message has arived).
And here is my attempt (failed) with deep sleep:
#include "heltec.h"
String packet;
packet ="";
void setup() {
LoRa.receive();
esp_sleep_enable_ext0_wakeup(GPIO_NUM_26, 1);
delay(10);
if (packetSize) {
cbk(packetSize);
Serial.println("Message Processed");
Serial.println("Starting deep sleep");
//rtc_gpio_hold_en(GPIO_NUM_26);
esp_deep_sleep_start();
void loop() {
The LoRa radio is not sending DIO0 high to indicate a new message is "in", i am assuming it is leaving continuous receive mode but not sure how to keep this from happening. I have verified that GPIO26 will wake the ESP32 when 3.3v is applied, and have an LED on GPIO26 to indicate when it is high.
