Well yes you can do a lot of multitasking like things with a giant loop of state machines, but it can get messy in some cases.
Taking the SD card example again. Once you issue the call into the FAT32 library you are essentially giving it control of your time sharing since the library was likely something you taken from someone else (If you didin't then you have way too much time on your hands). It won't return until its done with what you asked it to do. And a FAT32 library can become quite busy sometimes. A single call into it could send it looking for the allocation table, realising it doesn't have it ready, then realising it has dirty data in its sector buffer since you can't afford lots of RAM dedicated to that so it has to first flush that, get the allocation table data, realize it needs another part of it from somewhere else, modifies the table and its other copy because its FAT32, flushes all that out and then finally places the piece of data in the location you asked to write upon finally returning back out. In the process making a heap of random read and write accesses to a old crappy SD card that has abysmal random access performance so by the time you get back out of there a lot of time has passed. You could have the sd card driver call some functions to do usefull work while its waiting for data but then those function get time assigned to them very eraticaly and if they set off something that ends up talking to the FAT32 library or the code that started the FAT32 call you could have mangled some data or got into a call loop that eats up the whole stack and crashes. It even does it in that nice random non reproducible way that is a nightmare to troubleshoot.
Not saying that RTOS is a magical wand that fixes all this. If a RTOS is used wrong it can cause huge slowdowns and resource usage and you shouldn't be running like 100 threads in it. But when well thought out to keep the number of threads and context switches down it can make things run very efficiently while providing great and reliable millisecond accurate timing for the semi time critical things. The really time critical things you simply do in oldschool high priority interrupts to take control away from the RTOS and get your nanosecond timing for where you really need it. That way you get the best of both worlds.
