Yeah that's not a problem for this. It doesn't need dynamic allocation or any heap really. There's one command buffer and a bunch of configuration and state variables that are global and that's it. In the current incarnation it's all in a big for loop with one procedure for each task and the task when it gets called checks for state change in the globals it knows about and then reacts, or changes the variable based on panel controls etc. Interrupts only mutate the global state at the moment. Makes serial handling difficult to add so adding FreeRTOS here makes stuff easier with queues so I can deliver events instead of watching state.
Inputs for this are: rotary encoder, 5 buttons, 5 ADC inputs (multiplexed), serial port, 2 GP digital lines.
Outputs are: serial port, 3 DAC outputs, one synthesizer IC (I2C), one 44780 LCD, 6 GP digital lines.
uC just controls state or listens to it via serial port and reports it on the display. No intelligence going on.
