Author Topic: EAGLE library, locking for motorola's one  (Read 2480 times)
Offline legacyTopic starter
« on: March 04, 2014, 08:53:39 am »
hi guys
i'm new about the EAGLE Cad, i recently installed the program and i have been learning it.
for i very tiny project i need these two parts (1) and it seems EAGLE is not provided with.
i have found a very old library for the mc68ez328, but EAGLE says "too old, it is previous v4.4" refusing to import it
so what could you suggest me to do ? to create a library from the scratch ? in case, any suggestion is welcome
(1)
- mc68hc11 in PGA52 package
- mc68EZ328 in tqfp100 package
Re: EAGLE library, locking for motorola's one
« Reply #1 on: March 04, 2014, 09:24:13 am »
this is the mc68ez328 library i am not able to import
it seems 4 years later
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #2 on: March 04, 2014, 09:25:42 am »
Ah. You must be one of those 'component library part creation-phobes'.
I used to be like you.
Once you start making your own component parts you will never look back. This is probably a good time to start. I know it's not fun but it's part of the process. :)
Offline westfw
« Reply #3 on: March 04, 2014, 09:48:40 am »
If you're not on a windows box, try reading the library on one and writing it out in a more modern format.
For some reason, non-windows versions of EAGLE seem to have less legacy format support.
« Reply #4 on: March 04, 2014, 10:30:24 am »
thank you guys
just an other question: is it possible to "grab" a component from a library and to add it to a brand new custom-library ?
if so, how to do it ?
also … is there a library populated ONLY with packages ?
Offline kile
  • Country: hu
« Reply #5 on: March 04, 2014, 01:41:02 pm »
Yes, that is possible. Open the new custom library in the library editor, then go to the EagleCAD Control Panel and under libraries/lbr find the library and the component that you want to copy. Then right-click the component and select "Copy to library".
