Hi
Would it be possible to control two MIPI displays with one microcontroller?
I have a design to do, this one has two small 3 inch screens with MIPI interface, on opposite sides of a cube. This cube rotates and at a given moment only one of the screens is visible, so it would help me to use only one microcontroller that plays the video, I can detect the position of the cube to know which video I have to play.
The first thing would be to know if I can share the data and clock differential pairs between two screens and if I would have to keep the track length the same for both screens, there are two data lanes and one clock.
Then I would have the problem of the Tearing signal (TE), from which only one of the two screens could be used, my question is if both screens still receive the same data at the same time, they could not be perfectly synchronized in terms of the Tearing signal to display perfectly stable image.
