Ok, I added the volatile words, and it doesn’t compile with any more or less words, and still works the same,
so I’ll leave it that way.. Thanks
I’d know if it was a problem because if the frame buffer wasn’t cleared, the screen would simply gradually turn black,
never clearing anything drawn to it, just as occurs if I comment out the function.
I was proficient with asm for 8 bit pics, such that I can still read and modify reasonable code, but do I really want to go there again?
My debugging hasn’t evolved far either. I still serial debug this with a serial routine in code, a Commodre Amiga, and terminal program, and CRT monitor!
To measure this loop I’d output a pulse once per call to the function that updates the display, and use an actual frequency counter to count framerate.
I am aware this is funny for these times, but given my understanding of DSPs and the repeat, I trust this is going to be faster that anything else.
