Author Topic: does anyone interested in 20 cent RISC-V MCU?  (Read 11131 times)
Offline zepan0Topic starter
  • Country: cn
« on: May 28, 2019, 04:05:39 am »
Hi, we are sipeed team who made the MAIX project (AI on RISC-V)
We decide to make an RISC-V board in $1, which made with 20 cent RISC-V 32bit MCU(maybe with usb).
Does any one interested in it? Do you have some suggestions?
The following users thanked this post: FlyingDutch
Online ataradov
    • Personal site
Re: does anyone interested in 20 cent RISC-V MCU?
« Reply #1 on: May 28, 2019, 04:21:06 am »
Do you have specific silicon in mind? Or are you planning on making a new device?
I'm interested in 20 cent MCU on its own, but it all depends on the package and peripheral set. The board would be a nice starting point, but the MCU is the primary thing here.
Alex
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #2 on: May 28, 2019, 04:37:02 am »
I would personally be more interested in a big risc-v SoC that can run Linux.
Email: OwOwOwOwO123@outlook.com
Offline hamster_nz
« Reply #3 on: May 28, 2019, 04:46:53 am »
As you most likely guessed, I would be interested in it, but as I am purely a hobbyist who is  interested in the RISC-V architecture I can't see me acquiring more than a few for experimentation.
However, it would be important milestone for the RISC-V platform to have an offering that is price comparable with the ESP32. Although I own a SiFive HiFive1 one board I will only ever own one due to the cost (US$59) and relatively low spec. The K210 is almost there... but not quite.
Also, one of the key things that the current range of low-cost ESP32 modules lack is an efficient LDO for working with battery solutions. The standard 'go-to' LDO of an AMS1117 has a uses ~10mA, but the standard ESP32 sleeps at 70uA, so 99% of the power is wasted when sleeping. When you want a battery or solar powered solution the option of 70mA when  running, and 10mA when asleep is very poor compared to 60mA when running, and 0.1mA when asleep.
If a 32-bit RISC-V, with USB (either on-chip or a separate CH340g) was available in a form factor that is something like the link below, and I had some confidence in deep-sleep performance (1mA or hopefully much better) I would be very interested, it would be a viable option for my tinkering.
https://www.aliexpress.com/item/New-ESP32-Lite-V1-0-0-for-wifi-Module-bluetooth-board-based-ESP-32-esp-32/32841073426.html
One problem I have had with the ESP32 boards is that their footprint changes every 6 months, so I can no longer easily get the boards I was using last year. If only from the outset somebody make room for a battery controller + JST connector, reset/boot switches, SD card, whatever, and freeze the pin-out and outline.
I would far rather pay a few cents more for a slightly larger PCB with more pins broken out (and maybe some do-not-populate parts) than save a few cents but have the footprint keep changing.
Would you be thinking of a controller package that I can work with at home? Or at that price point is the most economical package a must?
« Last Edit: May 28, 2019, 04:48:57 am by hamster_nz »
Offline hamster_nz
« Reply #4 on: May 28, 2019, 04:52:35 am »
Oh, and that project is awesome. I hope has been successful for you.
It is very interesting and exciting hardware, and is the part I show people if they ask what I am tinkering with. It is currently a DSP-based guitar tuner.  :D
If anybody hasn't seen the $20 kit here's the link:
https://www.seeedstudio.com/Sipeed-M1w-dock-suit-M1w-dock-2-4-inch-LCD-OV2640-K210-Dev-Board-1st-RV64-AI-board-for-Edge-Computing-p-3207.html
Online PCB.Wiz
« Reply #5 on: May 28, 2019, 05:47:44 am »
What does (maybe with usb) mean ? Does that mean USB inside the 20 cent RISC-V, or a USB download bridge added to the board ?
What are the specs of this 20 cent RISC-V 32bit MCU - package/MHz/Vcc/Peripherals/Flash/RAM ??
Offline lollandster
  • Country: no
« Reply #6 on: May 28, 2019, 06:23:44 am »
For personal projects I'd love a RISC-V alternative to the Cortex-M, but good documentation is a must for me. For professional usage, no interest (but I'm in a high cost, low volume type of business).
Offline emece67
« Reply #7 on: May 28, 2019, 06:26:24 am »
« Last Edit: August 19, 2022, 02:22:50 pm by emece67 »
  • Country: cn
« Reply #8 on: May 28, 2019, 02:32:50 pm »
more info,  it will be like a clone of stm32, but with RISC-V core, and high-end version will have USBFS.
Offline NorthGuy
« Reply #9 on: May 28, 2019, 02:52:30 pm »
I think there are lots of people who would be interested in 20 cent MCU with HS USB module, especially RISC-V.
As to the board, even if I bought it, I would never buy more than one or two, so it's not much difference for me personally, if it's $1 or $20. Shipping will dominate anyway.
The following users thanked this post: KL27x, cpt.armadillo
Offline FlyingDutch
« Reply #10 on: May 28, 2019, 04:41:26 pm »
Hello,
some time ago I bought more advanced version of "Maix-1": Sipeed Maix-1 RISC-V Dual Core 64bit With FPU AI Module Core Board in banggood.com.
After terst I can say that it is awsome  ;D
I am interested in simpler version 32-bit (one core) of RISC-V ICs. Good luck in your enterprise.
Best Reagards
Online ataradov
    • Personal site
« Reply #11 on: May 28, 2019, 05:09:19 pm »
If it is really a clone of STM32, it will be a great seller.  But we need to clarify what is meant by the "clone". The key here is to have similar electrical design too. If your device will need separate core voltage regulator, or take up a whole bunch of pins for external filters for the PLLs or something like this, then it becomes less interesting.
Alex
Offline lucazader
« Reply #12 on: May 28, 2019, 07:22:22 pm »
I would definitely be interested in a 20c high performance risc-v microcontroller.
I use stm32's all the time at work.
It would be good to have a cheaper options that uses nice open source tools (like gcc or llvm) like the risc-v architecture does.
Is it planned to have internal flash or external flash?
Do you have a planned target performance, eg target MHz, target mips etc?
Do you have a planned target power consumption (uA/MHz) and or a target sleep consumption?
Offline ehughes
« Reply #13 on: May 28, 2019, 11:31:52 pm »
I would rather see something that is more expensive.    Outside of hobby LED blinkers,     customers are looking for good support, reliability,  documentation, long term availability and good supply in the distribution channel.
I can't see a $0.20 part being useful outside of throw away toys and hobby projects.        I would rather see a robust device with the RISCV architecture being used in a useful offering of parts.
« Last Edit: May 29, 2019, 02:27:30 am by ehughes »
Online ataradov
    • Personal site
« Reply #14 on: May 28, 2019, 11:39:12 pm »
You are assuming that $0.20 device will be bad, it does not have to be that way. I assume that the hardware would be at least competitive with high end Cortex-M0+ devices.
Documentation is an open question. But I can live with bad documentation for some time if the chip is new. I'm sure documentation will improve if it becomes clear that the chip is good and worth using.
Alex
Offline wilfred
« Reply #15 on: May 29, 2019, 12:49:27 am »
I'm not sure that was the assumption. It could be if the price was $3.20 it'd be fine and a much more robust option. Even if it was the same device. Apple products are the exception of course. That Apple products exist shows there is a market for products that are needlessly expensive. I'm not trying to bash Apple, my point is that there are those for whom price equates to quality. It might be true for Italian shoes and handbags. Less true for Italian sunglasses and not true for technology especially where the development was funded by taxpayers and the price reflects manufacturing and labor costs.
Offline NorthGuy
« Reply #16 on: May 29, 2019, 01:14:22 am »
... there are those for whom price equates to quality.
I'm sure engineers know better than this.
Offline wilfred
« Reply #17 on: May 29, 2019, 01:50:34 am »
Read here long enough and you might be less certain. But that's not a debate I want to start.
Offline Fire Doger
  • Stefanos
« Reply #18 on: May 29, 2019, 06:12:39 am »
There are 3 types of buyers:
Hobby
prof short life production
prof long life production
For long life productions it's hard to sell because they want chips to be available in 10-15 years and they don't mind pay a bit more on famous brands to be safe.
short life productions depends on specs, price, documentation and availability. If you can only find it in China it won't be the first choice, for a few cents they will prefer stm etc...
For hobby if someone makes *arduino* plugin it will sell like crazy if at ebay costs 1-1.2€
Personally I choose based most on ease of use to deliver faster to market.
Debug! If I can't debug it properly it's a toy...
Reliable and cheap debug tools or use existing tools (Jlink etc)
Good abstraction layer libs (well documented) and many examples, many!
Open dev boards with many peripherals. I like having a reference for peripherals, transceivers, etc... Plus bread-boarding time costs money at work.
Support
Then there is the classical comparison of specs-price...
I would consider buying a dev board if it had a ton of examples, otherwise I will wait someone else to make the hard work first...
Offline westfw
« Reply #19 on: May 29, 2019, 07:16:26 am »
A scalable instruction set is relatively meaningless unless chip vendors implement devices at "many" of the price/performance points.  RISC-V will be a bit disappointing if all the chips that come out for sale are of linux-level complexity and performance, and I am very interested in seeing a low-end microcontroller-class RISC-V chip.  At least from an academic point of view; I'm afraid I can't promise to buy millions of them :-(
However, I'm worried about software support.  In the ARM world, there are plenty of small Cortex-M0 and M0+ chips, but the state of "small" compiler libraries is still pretty poor - libgcc still lacks optimized software floating point (which exists for CM3/CM4), newlib (even in it's "nano" configuration) is significantly larger than the similar libraries available for 8bit CPUs (ie avr-libc), and vendor libraries also seem to assume relatively large program space.  I can see RISC-V falling into the same trap.
Hobby, prof short life production, prof long life production
I'll add a forth: "Educational and academic" - for instance, AFAIK, MIPS is much more popular in university classes on assembly language and computer architecture than it is in the marketplace.   Academic users don't necessarily buy chips (vs simulation), but it would be good to have that option.
Offline Fire Doger
  • Stefanos
« Reply #20 on: May 29, 2019, 08:45:48 am »
Meh, for marketing I agree but you can't make profit as chip manufacturer from educational and academic, most of vendors gives them for free at students to get them familiar with their tools-chips.
They have the same demand with hobby buyers: cheap tools, low quantity, dip package, nice documentation
Microchip had very cheap pickit3 (and clones cost a few $) with debug and gives free IC to everyone with academic domain email...
« Last Edit: May 29, 2019, 08:48:12 am by Fire Doger »
Online neil555
« Reply #21 on: May 29, 2019, 09:59:04 am »
I'd definitely be interested depending on how much SRAM was included, at least 64K would be good
Offline tszaboo
« Reply #22 on: May 29, 2019, 03:55:10 pm »
Interesting? Depends on the ecosystem.
If it has USB bootloader, interesting peripherals, easy to start with IDE (think of Arduino) with a way for professionals to continue, than it can be a hit.
Like if you build in battery-power management with USB charging, and and RF interface, like Bluetooth, Zigbee or 802.15.4, you would be selling the chip in the billions.
Online PCB.Wiz
« Reply #23 on: May 29, 2019, 07:31:54 pm »
That will not be the banner '20 cent RISC-V MCU' anymore...
USB was mentioned in a 'more expensive part' and any RF bumps it further up the price curve, well away from the banner '20 cent RISC-V MCU"
Offline tszaboo
« Reply #24 on: May 29, 2019, 09:20:31 pm »
Without new features, it is just "yet another microcontroller" . I mean the CH554 costs 25 cents, and around 1 USD, there are already Cortex M0+ with USB from digikey. I mean, you need to show something new, because if you just have a new core, nobody will care.
