I posted previously about getting some EPROM chips programmed, see thread here
https://www.eevblog.com/forum/microcontrollers/uvprom/msg4856921/#msg4856921 I was able to get them programmed professionally at a very reasonable price, but there is a problem and I thought it best to create a new thread.
There are 4 .bin files on 4 EPROM chips, and they contain the firmware for a piece of HP Test equipment (8341B). The original firmware was 1988, and the new .bin files are the updated 1992 firmware. It should just be a straight swap, program some EPROM's with the 1992 firmware and swap out the originals.... only it hasn't worked, the instrument won't boot at all and I had to put the old chips back in with the original firmware on.
I realise this isn't a test equipment or repair section of the forum, but my question is... would changing the .bin filename have any effect on the data programmed into the EPROM ?
original filenames were
8340BU34,TITMS27PC256-2Rev1992
8340BU35,TITMS27PC256-2Rev1992
8340BU36,TITMS27PC256-2Rev1992
8340BU37,TITMS27PC256-2Rev1992
And to make things a bit simpler I renamed them to
U34
U35
U36
U37
And I'm just wondering now if doing that has caused it not to work. I don't really know enough about programming EPROMS to know if it could or not.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
**edit** just incase anyone notices the instrument is 8341b, and the .bin files say 8340b. It's the same firmware for both so thats not the problem.
